🔹 Card-mod - Add css styles to any lovelace card
Did you forget some card_mod CSS?
I copy paste your example:
     - type: vertical-stack
        cards:
            icon: mdi:mushroom
            icon_color: orange
            primary: Example
            card_mod:
              style: |
                ha-card{
                  background: none;
          - type: custom:layout-card
            layout_type: custom:grid-layout
            layout:
              grid-template-columns: 1fr 1fr 1fr
              margin: -15px 0
            cards:
              - type: custom:ring-tile
                entity: sensor.wohnzimmer_temperatur
                ring_only: true
                ring_only: true
                ring_only: true
Looks complete different and not like one card.
I think I need a vertical-stack-in-card to looks like one card together:
And then withour card_mod card i cannot change the tile card to change the background
I use
type: custom:stack-in-card
mode: vertical
Makes no different when I use some kind of vertical stack in card it likes one card. But the card_mod inside is not working without card_mod card
      - type: custom:stack-in-card
        mode: vertical
        cards:
            icon: mdi:mushroom
            icon_color: orange
            primary: Example
            card_mod:
              style: |
                ha-card{
                  background: none;
                  border: none;
            layout:
              margin: -15px 0
            cards:
                ring_only: true
                card_mod:
                  style: |
                    ha-card {
                        background: red;
                        border-radius: var(--ha-card-border-radius,12px);
                        box-shadow: none;
                        border: none;
                        margin: 0px;
                ring_only: true
                ring_only: true
custom:stack-in-card has ha-card so standard card_mod can apply. I expect you were looking too high or low in the DOM tree.
This works for me.
mode: vertical
card_mod:
  style:
      ha-card {
          background: red;
          box-shadow: none;
          border: solid;
          margin: 0px;
Just an update on this one.
  • While only having card-mod loaded as a dashboard resource and not as a frontend module
  • Experiencing card-mod render failures on casted dashboards, unless I casted them twice
I was looking through my browser console log and found a message along the lines of. “You are missing out on performance improvements by not using card-mod as a frontend module”
I took another look at the Card-Mod 3 ReadMe
Performance improvements
While card-mod can be installed as a lovelace resource, some functionality will benefit greatly from it being installed as a frontend module instead.
To do that, add the following to your configuration.yaml file and restart Home Assistant:
frontend: extra_module_url: - /local/card-mod.js
You’ll need to adjust that path according to where you have installed card-mod.js. If you installed through HACS, this is probably /hacsfiles/lovelace-card-mod/card-mod.js.
Any resource definitions automatically added by HACS can be kept as is even after adding extra_module_url.
So I added card-mod as a frontend module again
frontend:
  extra_module_url:
    - /hacsfiles/lovelace-card-mod/card-mod.js
While leaving my resource definitions automatically added by HACS in place
RESULTS
  • Dashboards casting reliably again and loading card-mods a lot faster
  • Dashboards displayed on PC, Raspberry Pi and Chrome OS all have card-mods loading a lot faster.
I feel this line has been added to the ReadMe since we last visited this.
No it has been that way for a while. You can have in both dashboard resources (needed for cast) and Frontend module (best for performance) but the URLs must MATCH EXACTLY, otherwise non CAST browsers will run card-mod Javascript file twice.
I edit my post, the issue is not the card_mod from the stack-in card.
The problem is when I use a stack-in card the card_mod of the ring tile card is not working.
I am assuming the way I have it above is the same url? With the hacstag being the only difference?
Yes, so in your Frontend module url, incude the hacstag, and update whenever card-mod is updated by HACS. Basically take the HACS dashabord URL in full and paste into Frontend module section.
Will do, thanks for the clarification. This probably needs to be a bit more explicit in the ReadMe
For now I point to my comment in the issue where this was discussed. I may submit a PR for the readme, but anyone can :slight_smile:
Stack in Card rearranges the layout so you’d have to use something like this
mode: vertical
cards:
    icon: mdi:mushroom
    icon_color: orange
    primary: Example
    layout:
      margin: "-5px 0"
    cards:
        entity: sensor.living_room_humidity
        ring_only: true
        bottom_element: name
        entity: sensor.living_room_temperature
        ring_only: true
        ring_only: true
card_mod:
  style:
    hui-vertical-stack-card$:
      layout-card$:
         grid-layout$:
          ring-tile:nth-child(1n)$: |
            .background {
               background: #e67e00 !important;
      ha-card {
          background: grey;
          box-shadow: none;
          border: 1px solid white;
Color only for effect
Noted. Looking at ring-tile it uses the property _cfg and not config or _config so card_mod can’t read the config so you would need mod-card in this case.
EDIT: Noting @LiQuid_cOOled solution which is valid styling from a parent where card_mod can be applied.
I avoid stack-in-card for the complexity it adds and use vertical-stack-in-card instead.
But why??
Why not stick to entities or vertical-stack (or grid for certain requirements)
Those container cards can do everything (helped by card-mod here and there)
And 100% stock cards is always preferable
Especially to vertical-stack-in-card which has a history of causing inconsistencies and trouble…
But with a vertical-stack-in-card I need the same card_mod right? Because I tried both cards and always same issue directly on the ring tile card is not working. So you would recommend to use custom:vertical-stack-in-card, right?
Just for my interest what is better to use this complex css instead of the card mod card?
      layout-card$:
         grid-layout$:
            .background {
Don’t get me wrong, I use stock cards before any mod card. Grid card is my go to.
custom:vertical-stack-in-card background mods are simpler than most.
card_mod:
  style: |
     ha-card {
          background: red;
I get better load response times with this vs the stack-in-card
Try both side by side and refresh your browser.
type: custom:vertical-stack-in-card
cards:
    icon: mdi:mushroom
    icon_color: orange
    primary: Example
    card_mod:
      style: |
        ha-card {
          background: grey;
    layout:
      margin: "-5px 0"
    cards:
        ring_only: true
        ring_only: true
        ring_only: true
card_mod:
  style:
    layout-card$:
      grid-layout$:
          div.background {
      ha-card {
           background: grey;
           box-shadow: none;
In case anyone else has this issue, I’ve found the right path with the inspector.
Removed the ugly blue background to all of these action buttons and updates the font color
    card_mod:
      style:
        hui-call-service-row $: |
          ha-button::part(base) {
            background: transparent !important;
            box-shadow: none !important;
            border: none !important;
          ha-button::part(label) {
            color: grey !important;
Cool works :slight_smile: and yes performance is better and easier to read :slight_smile:
Thanks a lot
