šŸ”¹ Card-mod - Add css styles to any lovelace card
You might need to use mod-card, shadow-root into mod-card, and then shadow-root into the card.
experimenting some more with modding top view badges:
badges:
  - entity: person.marijn
    style:
      ha-state-label-badge:
          ha-label-badge:
              .label-badge .label span{
                {% if is_state('person.marijn','home') %} color: purple;
                {% else %} color: black;
                {% endif %}
          :host {
            {% if is_state('person.marijn','home') %} --label-badge-red: gold;
            {% else %} --label-badge-red: grey;
            {% endif %}
I was kinda hoping we could use ā€˜entity’ in the templates, like
                {% if is_state(entity,'home') %} color: purple;
                {% endif %}
making it easier to use anchors and stuff… a bit like we can in Thomas’s other card with jinja templates. Obviously this doesn’t work, but maybe I am not using it correctly, and this is a user error? would this be in any way possible?
thanks for having a look.
Is it possible to style an entity’s secondary_info only and not the main entity itself?
Try searching here using ā€œsecondary_infoā€ keyword, you will find solutions for Entity, Glance, Entities, multiple-entity-card…
Newbe challange:
My end goal is to change the font of the temperature in a weather-forecast card but I’m not able to get the style element inserted in the right place (I guess) with shadow-roots etc…
Example code:
              - type: weather-forecast
                entity: weather.home
                debug_cardmod: true
                style:
                  hui-weather-forecast-card:
                      ha-card:
                          .content {
                show_forecast: false
The end goal (I guess) is to get a style tag inside the temp div or?
Hope any css/frontend guru can help :slight_smile:
BR.,
Lars
Wondering if anyone can help with an animation.
I have a conditional card that I want to animate its arrival on screen. I have managed to make the card fade in, but I want the space the card takes to slide open. The link is a video showing what I have, and the code is below. Any help would be fab:
type: vertical-stack
cards:
  - type: grid
    columns: 1
    square: false
    cards:
      - type: picture
        image: local/header_information.jpg
        tap_action:
          action: navigate
          navigation_path: /lovelace/upstairs
        hold_action:
          action: none
  - type: conditional
    conditions:
      - entity: input_boolean.show_calendar
        state: 'on'
    card:
      type: 'custom:atomic-calendar-revive'
      entities:
        - entity: calendar.bin_collection
      name: Bin Collections
      enableModeChange: true
      firstDayOfWeek: 1
      maxDaysToShow: 14
      showDate: true
      style: |
        ha-card{
        animation: fadeIn ease 2s;
        -webkit-animation: fadeIn ease 2s;
        -moz-animation: fadeIn ease 2s;
        -o-animation: fadeIn ease 2s;
        -ms-animation: fadeIn ease 2s;
        @keyframes fadeIn {
        0% {opacity:0;}
        100% {opacity:1;}
  - type: conditional
    conditions:
      - entity: input_boolean.eufy_advanced_settings
        state: 'on'
    card:
      type: entities
      entities:
        - entity: input_datetime.eufy_schedule
        - entity: input_boolean.eufy_weekend_clean
        - entity: vacuum.robovac
          name: Eufy Start / Stop
        - entity: input_boolean.vacuum_disable
  - type: grid
    columns: 3
    cards:
      - type: button
        tap_action:
          action: navigate
          navigation_path: /lovelace/security
        entity: alarm_control_panel.ha_alarm
        icon: 'hass:bell-outline'
        show_state: true
      - type: button
        tap_action:
          action: toggle
        entity: input_boolean.guest_mode_switch
        show_state: true
        show_name: true
        show_icon: true
      - entity: input_boolean.house_option_alarmclock
        hold_action:
          action: more-info
        show_icon: true
        show_name: true
        tap_action:
          action: navigate
          navigation_path: /lovelace/alarmClock
        type: button
        show_state: true
      - entity: climate.zone_1
        hold_action:
          action: navigate
        show_icon: true
        show_name: true
        tap_action:
          action: more-info
        type: button
        show_state: true
      - type: 'custom:button-card'
        aspect_ratio: 1/1
        entity: input_select.bins
        hold_action: none
        tap_action:
          action: call-service
          service: input_boolean.toggle
          service_data:
            entity_id: input_boolean.show_calendar
        show_icon: true
        show_name: false
        show_state: true
        show_label: true
        label: |
            return 'Collection: ' + states['sensor.bin_day'].state;
        state:
          - value: Recycling
            color: 'rgb(50, 50, 50)'
          - value: Refuse
            color: 'rgb(21, 150, 49)'
          - value: Garden
            color: 'rgb(92, 65, 12)'
        styles:
          icon:
            - margin-top: '-20px'
            - margin-bottom: 0px
          name:
            - font-size: 12px
            - color: 'rgb(150, 150, 150)'
          state:
            - margin-top: '-55px'
            - padding-bottom: 10px
          label:
            - font-size: 12px
            - margin-bottom: 20px
        hold_action:
          action: more-info
        icon: 'mdi:robot-vacuum'
        show_icon: true
        show_name: true
        show_state: false
        tap_action:
          action: toggle
        type: button
Looks like the font size is set in :host, but how do I override that for div class ā€œtempā€?
I’m confused. You might be able to do this by progressing from height: 0; to height: unset;.
I’m getting really close now!
I have managed to make the item slide in as i want, but I don’t know how to make it animate slide back out.
See the video of it sliding open:
This is the style code I have so far:
style: |
    ha-card{
    animation-duration: 1s;
    animation-name: slidein;
    @keyframes slidein {
    0% {
    opacity:0;
    margin-bottom: -200px;
    100% {
    opacity:1;
    margin-bottom: 0px;
Styling Weather Card:
    entity: weather.home_met
    show_forecast: true
    card_mod:
      style: |
        .name-state .name {
          color: orange;
          font-size: 2px;
        .name-state .state {
          color: red;
          font-size: 7px;
        .temp-attribute .temp {
          color: green;
          font-size: 40px !important;
        .temp-attribute .temp span {
          color: blue;
          font-size: 7px !important;
        .temp-attribute .attribute {
          color: cyan;
          font-size: 7px;
        .forecast .temp {
          color: orange;
        .forecast .templow {
          color: blue;
        .forecast div {
          color: magenta;
How to replace the main picture:
card_mod:
  style: |
    svg {
      display: none;
    .icon-image {
      background-image: url("https://www.pngall.com/wp-content/uploads/11/Weather-No-Background.png");
      background-size: 100% 100%;
      height: 64px;
More examples are described here.
Thx :slight_smile:
BR.,
Lars
Hi all,
hope someone can help me out…
How can I reach the highlighted #root div in the picture above?
This is one of several attempts I’ve made, but I’m a bit loss…
type: "custom:mod-card" # MOD CARD FOR HORIZONTAL STACK
style:
    ha-card {
      background: rgba(255, 255, 255, 1);
      height: 70px !important;
      margin: 0 5%;
      width: 90%;
      position: absolute;
      bottom: 10px;
      border-radius: 35px;
      text-align: center;
    hui-horizontal-stack-card:
        #root {
          justify-content: center !important;
          align-items: center !important;
card:
  type: horizontal-stack # HORIZONTAL STACK FOR TOP BANNER
  cards:
    - type: "custom:button-card"
You indented hui-horizontal-stack-card:. It should be 1 less indented.
Instead of using a conditional card, show/hide it using Jinja templating.
That sounds way beyond my pay grade!
Do you get the first part? Do that first, and then I’ll explain it.
You have lost me - what first part?
Make it so that the card always displays, instead of being inside of a conditional.
Damn, I knew I was missing something stupid!!!
Thank you so much.
Ah - I see. So obviously I can make the card into a standard entities card. How would Jinja be used to make the card show / hide when a button is pressed then?
