🔹 Card-mod - Add css styles to any lovelace card
I would like to modify the standard light card for a dimmer with three goals:
  • eliminate the three dots for the more-info menu
  • make the background transparent
  • let the icon keep its color instead of changing with dim level / brightness
I managed to achieve the first two but I’m stuck with the third. Any advice?
type: light
entity: light.shelly_leo_dimmer
style: |
  mwc-icon-button.more-info {
    display: none;
  ha-card {
    background: none;
2021-01-30_13-37-31
Inspecting the document, I can see that a filter: on ha-icon-button is responsible for the changing color. However, setting it to none doesn’t seem to have an effect:
type: light
style: |
    display: none;
  ha-card {
    background: none;
  ha-icon-button {
    filter: none;
I feel like missing something obvious.
The filter is responsible for the brightness; you also need to set color.
I don’t think it is that easy. The following has no effect:
type: light
style: |
    display: none;
  ha-card {
    background: none;
  ha-icon-button {
    filter: none;
    color: green;
Use !important
Thanks, yes, that was it!
type: light
style: |
    display: none;
  ha-card {
    background: none;
  ha-icon-button {
    filter: none !important;
2021-01-30_16-24-23
Thank you very much! I am wondering where I can put the Variable so that I can reuse it in other cards.
In your theme.
Can you break down how you got to this selector? I tried to apply my selector knowledge this morning and did not get the same result (or a working result).
Oh, that was an old post. Could you share what you came down to?
I don’t remember what I originally had. But I’m wondering how you get the initial selector point. How did you know to use layout-card$?
That was the name of the card’s element.image
So where’s the $ come from, why is it at the end? Is that something new in the custom card?
This was the old syntax:
style:
  element-card:
      another-thing:
This is the new syntax:
style:
  element-card$another-thing$: |
Ah ok, thanks
Could you explain what means “the new syntax”, shall we use it from now, will it work everywhere?
And to add to that: Will the old syntax stop working, or is the new syntax more like syntactic sugar?
Could you explain your question more?
If you want.
I don’t know, but in all of my uses so far it’s worked.
I think it will still work.
It does fix a problem with the old syntax that stopped you from shadow-rooting into an element inside of a shadow-root
Please give me an example of this, I did not get the point, thank you!
This originally worked, then stopped working:
style:
  element-card:
      another-thing:
When the new syntax came out, it worked.
Sorry being late:
I achieved it the way as bellow. See, it’s content of entities card
type: entities
title: Kitchen
entities:
  - entity: light.kitchen
    icon: 'mdi:dome-light'
  - entity: light.kitchen_worktop
    type: 'custom:multiple-entity-row'
    state_header: Main
    toggle: true
    state_color: true
    style:
      ha-entity-toggle:
          ha-switch {
            padding: 0px;
I have also another example this time multi entity is embeded into restriction-card
entities:
  - type: 'custom:restriction-card'
    action: double_tap
    style:
      multiple-entity-row$:
        ha-entity-toggle$: |
          ha-switch {
              padding-top: 0;
          state-badge {
            line-height: 20px;
            height: 30px;
        ha-icon {margin-top: 5px}
before
after
