pex81
(Pex81)
February 6, 2021, 2:07pm
1379
Hi, can I change state color ?
- type: picture-elements
image: /local/images/computer/synology_ds1515.png
elements:
- type: state-icon
entity: sensor.nas_drive_1_status
style:
top: 30%
left: 25%
'--paper-item-icon-color': var(--my-icon-color)
- type: state-icon
entity: sensor.nas_drive_2_status
style:
top: 30%
left: 37%
I try this code but nothing:
style: |
ha-card {
--my-icon-color: {% if is_state('sensor.nas_drive_1_status', 'normal') %} green {% else %} red {% endif %}
KTibow
(Kendell R)
February 6, 2021, 2:40pm
1380
You can just use state_filter for that without card_mod.
pex81
(Pex81)
February 6, 2021, 3:04pm
1381
Thanks, but state_filter not set color.
pex81
(Pex81)
February 6, 2021, 3:38pm
1383
thanks all the same but i solved with this code using condition
elements:
# Synology Drive 1 Status
- type: conditional
conditions:
- entity: sensor.nas_drive_1_status
state: "normal"
elements:
- type: state-icon
style:
top: 30%
left: 25%
"--paper-item-icon-color": greenyellow
- type: conditional
conditions:
state_not: "normal"
elements:
- type: state-icon
style:
top: 30%
left: 25%
"--paper-item-icon-color": red```
nathagt
(Nathan Thompson)
February 6, 2021, 8:06pm
1384
First post here. Having some trouble applying custom color to my icons on the simple-thermostat card using card-mod. Iām using the raw editor and I know card mod is installed correctly because Iām able to change colors on an entities card just fine. Below is what I have for the thermostat. I used inspector in Edge/Chrome to see where the color is coming from and Iām thinking it might be because it is inherited from shadow-root? I just donāt know why. I have no theme applied. Iāve tried a lot of different ways of changing the color including rgb(), typing it, or using the #hex . No matter what I do the auto color will not change from springgreen. Iām sure itās something simple I am missing. Can anyone suggest a fix?
- type: 'custom:simple-thermostat'
entity: climate.thermostat
sensors:
- entity: sensor.thermostat_humidity
control:
hvac:
heat:
icon: 'mdi:fire'
cool:
icon: 'mdi:snowflake-variant'
heat_cool:
icon: 'mdi:cached'
style: |
ha-card.mode-item.active.off {
background: red;
ha-card.mode-item.active.heat_cool {
background: #efbd07;
I am not sure if I am getting your point.
You mentioned this code as ānot workingā:
style:
element-card:
another-thing:
I am not sure what do you mean by āelement-cardā, but this code works:
type: entities
title: 'Common: color icon'
style:
hui-text-entity-row:
hui-generic-entity-row:
state-badge:
ha-icon:
ha-svg-icon {
color: red;
entities:
- entity: sun.sun
- entity: sun.sun
KTibow
(Kendell R)
February 6, 2021, 9:02pm
1386
Try setting --heat_cool-color with !important to ha-card instead. You might need to use mod-card.
KTibow
(Kendell R)
1387
I guess the old syntax was fixed, too.
Well, at least using one more syntax gives us more flexibility!
just a thought, but would it all be possible have the overview posts separated into a Community Guide of sorts. No discussions there, those are done here, simply all posts like @Ildar_Gabdullin did for the various cards and stylings.
Right now, we need to go back and forth in this thread to find these (or save them locally, as I didā¦). I think it would be very beneficial to all of us to have them on display permanently.
With the separated/dedicated community guide, checking how to style a badge, or a font-size for Entities card would be a breeze.
123
(Taras)
February 8, 2021, 5:10pm
1391
I would appreciate guidance for suppressing the display of the entire toggle button in an Entities card.
Iāve tried enough things to confirm I donāt have a good grasp of the core concepts (i.e. seems straighforward in theory but not in practice). For example, I tried this but it doesnāt work:
type: entities
entities:
- entity: input_boolean.test
show_header_toggle: false
style:
ha-entity-toggle:
ha-switch {
display: none !important;
The toggle button is within a shadow-root and, based on my limitation understanding, that implies more complexity in how to define the item I wish to act on.
Viking
February 8, 2021, 6:57pm
1392
The doc says:
āI recommend using HACS to install and keep track of plugins .ā
But this plug-in is nowhere to be found in HACS ?
Is a custom repository needed to install it ? If so, whatās the URL ?
Hi.
Thanks for all your work and help here!
Iāve searched for a few days but cant seem to figure out how it actually works.
Iāve also read that there might be problems with picture elemts cards, but there was a work around?
I have 2 icons, which actually should show a debug boolean state (removed to simplify) but I just want to change the color depending on on/off state and the only way to do it seems to be card-mod.
elements:
- icon: 'mdi:android-debug-bridge'
title: Debug
type: icon
style:
'--mdc-icon-size': 40px
color: 'rgba(255, 0, 0, 0.6)'
background-color: 'rgba(3, 169, 244, 0.6)'
border-radius: 50%
top: 35%
left: 40%
padding: 10px 10px 10px 10px
title: Debug
type: icon
style: |
hui-icon-element {
color: blue;
image: /
But Iām unable to make the second icon use any of the attributes of the first icon.
Iāve also tryed the debug method of my browser and found some elemts names but they modify colors of the entire page.
<hui-icon-element class="element" style="--mdc-icon-size:40px; color: rgba(255, 0, 0, 0.6); background-color: rgba(3, 169, 244, 0.6); border-radius: 50%; top: 35%; left: 40%; padding: 10px;"></hui-icon-element>
Any help apreciated
Uh, Maybe I can hepl here!
I just made it work:
In Hacs, under Frontend, press ā+ EXPLORE & ADD REPOSITURIESā and search for card-mod. Think thats how I made it work!
Here all my posts which may be useful:
NOTE:
Do not forget to add a "card_mod:" keyword before "style:" (new in card-mod 3).
And also read this important note to create optimized code. In most examples here a code is NOT optimized - just to describe a DOM navigation.
Entity card
post
rotating icon (by @dolodobendan )
disabled tap_action
Entities card (including some special row elements - button , section , divider )
post
using standard vars for some domains
post
Entities card with attributes
post
Slider entity inside Entities card
main post
popup baloon issue
hide the popup baloon
"hui-input-number-entity-row" - entity row for "input_number"
main post
How to make input_number rows look less different from other entity rows - part 1 , part 2
input_select row
main post
How to make input_select rows look less different from other entity rows - part 1 , part 2
How to add secondary_info: last-changed
input-text row
post
How to make input_text rows look less different from other entity rows - part 1 , part 2
input_datetime row
part 1
part 2
How to make input_datetime rows look less different from other entity rows - part 1 , part 2
Conditional row inside Entities card
post
Toggle row inside Entities card
colored checkbox
how to disable a toggle button
how to disable a toggle button - inside auto-entities
moving toggle to the left
super narrow version
Hiding checkboxes inside Entities card
for some entity row
for all entity rows
Animations for Entities card
post
āChipā buttons
post
card-mod theme for chip buttons
changing styles for a particular button in a footer dependently on a state
changing an icon
Cover entity row
main post
disable a cover control conditionally
ānarrowedā look
Light entity row
how to show lights with using only āactiveā & āinactiveā colors
How to manage a rowās height
decrease height
increase height
How to shift rows to the right
post
How to center weblinks & commands
post
āEmpty slotā for Entities card
post
Circular progress indicator
post
Glance card
main post
changing margin
Allocate items in a compact manner
Place names below icons
entity-filter
style rows dynamically
Footer / Header
post
custom:multiple-entity-row
main post
displaying "last-changed" or any other labels for items
distribute items evenly
animated icons
dynamic icons
show values of 2 attributes in secondary-info
custom:fold-entity-row
main post
How to enable / disable a āfold / unfoldā control for fold-entity-row
RTL fix for a section row
custom:template-entity-row
main post
t-e-r inside a conditional row
custom:numberbox-card
post
custom:multiline-text-input-card
post
custom:text-divider-row
post
Tile card
colored icon & background on hover
remove background from an icon
dynamically set icon
adding a button
custom icons for features
long states
input_select: one-line look
Heading
post
change icons
Thermostat
Distribution card
customize a barās height
custom:bar-card
animation
2 text lines
displaying an image instead of an icon
centered title
hide the whole bar-card if all bars are hidden
replacing a value
adding a prefix
RTL fix for vertical bars
Gauge
disabled tap_action
colored needle
adding an additional label
āmirroredā gauge
markdown
scrollbar
scrollbar for some text
markdown with images
markdown with a table: post 1 , post 2 , post 3
colorize only some text
external js for āhrā element
styling an icon on hover (original idea of @Spartacus )
header
Picture Glance card
post
changing an icon by card-mod
distributing icons
changing a background image - post , also a config-template-card based way
Sensor card with a graph
post
History-graph card
styling
prevent clipping when using inside stack-in-card
added scrollbar
custom line colors
custom timeline colors
how to set a 0 lower bound for Y-axis
styling a tooltip
how to add an icon to a cardās title
how to set a height
statistics-graph card
post
grouping / aligning labels
custom line colors
replacing a label
custom:mini-graph-card
main post
animation - blinking name, resized & rotating icon
how to display an additional info on the card
how to display additional text items (prefixes & suffixes)
solid (non-semitransparent) fill
move a graph for the 2nd sensor to the bottom
how to set a color for the last bar
place 2 sensorsā states on the left side
displaying states as a part of the legend
displaying a UoM under the state
displaying a UoM before a state
displaying a state & extrema data on the same line
using card-mod to compare mini-graph-card & history-graph
non-elegant & unstable way to show labels for X-axis
fixing an issue with a card inside state-switch
imitating statistics card
how to nicely align legendās elements
compact view when used in horizontal stack or grid
styling Y-axis labelsā background
how to change graphās color dynamically
styling points
custom:apexcharts
RTL fix
Weather Card
post
Styling a card inside ācustom:config-template-cardā
post
Styling a card inside ācustom:decluttering-cardā + passing a style as a variable
post 1
post 2
Badges (before 2024.8)
important - fix to restore a possibility to style badges after 2024.8
Important - how to style badges in card-mod 4.x
Badges: different styling
Badges: conditional show/hide
Badges: hidden name
Square badges
Dynamic icon
Show either an icon or a value
Manually added UoM
Replacing a state
Replacing a UoM
Gradient colors for a badge dependingly on a value (by @parautenbach )
Horizontal spacing between badges
Badges (2024.8)
badges themselves
badges themselves (mod-card) by @arganto
themes - one , two , three
custom:badge-card
post
after 2024.8
Picture Elements card
main post
conditional elements
rotated background image
āselection areaā
3 ways to change an element dynamically
on-hover effect for elements
example: show a charging process
Logbook card
main post
styling images by using external js-module
Logbook in a Panel mode
styling a scrollbar (style is unstable)
Media Player card
post
custom:mini-media-player
post
vertical-stack, horizontal-stack
main post
How to fix the āmargin-topā problem for a hidden conditional card
Stack inside āhui-elementā card
Removing internal borders & margins inside vertical-stack
Line-breaks in horizontal stack
How to add an icon to a cardās title
Adding tap-action for stack-in-card
grid
customizing a grid in sections
custom:stack-in-card
main post
example of customizing a width in a horizontal stack
styling a header
prevent clipping of a tooltip of history-graph card & a dropdown list of an input_select
See next part below ā
123
(Taras)
February 8, 2021, 10:56pm
1398
Thank you! I think I now understand why the many things I have tried all failed to work.
If the Entities card contains multiple entities, is there a way to make the style apply to all of them? Or does it have to be repeated for each one separately?
