šŸ”¹ Card-mod - Add css styles to any lovelace card
I am preparing a dedicated post for picture-elements card.
Hope it will be ready within a week.
What do you need particularly?
Some effects may be done using a "picture-elements::element::style" (not by "card-mod").
Iā€™m glad to hear that, waiting for that post ā€¦
for example, make it rotate the icon of an input number into a custom: slider-entity-row card or de icon of type: state-badge
I have tried it with card mod and I have not got any, I do not clarify much either, so I really appreciate all your examples
Thanks again
I finally got it ā€¦
              elements:
                - type: custom:slider-entity-row
                  entity: input_number.zone_1
                  card_mod :
                    style:
                      hui-generic-entity-row:
                          state-badge:
                              ha-icon:
                                  ha-svg-icon {
                                    {% if is_state('timer.timer_1','active') %}
                                    animation: flipping 3s linear infinite;
                                    {% endif %}
                                  @keyframes flipping {
                                    0% {
                                      transform: rotateX(0deg);
                                    100% {
                                      transform: rotateX(360deg);
                  style:
                    top: 30%
                    left: 50%
waiting for your new postā€¦ :smiling_face_with_three_hearts:
Good! Other possible animations are described here.
The first post isnā€™t really visible, though.
That is right, but anyway we cannot solve everyoneā€™s problems if some people are not even trying to search a solutionā€¦
Also, people do not read docs - very often I see posts like ā€œI tried smth but it does not work - why?!ā€ - and this ā€œsmthā€ is even not described in docs as a supported feature; sometimes people invent new properties or take properties from other cards and ask questions like ā€œwhy this property does not work?ā€.
Sorry for my broken English, in Russian I speak betterā€¦
sharing a little snippet that makes cameras have a red outline when motion is detected
  - aspect_ratio: '16:9'
    camera_image: camera.north_roof
    entities:
      - entity: binary_sensor.motion_north_roof
      - entity: sensor.motion_recording_north_roof
      - entity: binary_sensor.kitchen_exit
    title: NORTH SIDE
    type: picture-glance
    card_mod:
      style: |
        ha-card {
          color: red;
          outline: {% if is_state('binary_sensor.motion_north_roof', 'on') %} solid {% else %} none {% endif %};
Iā€™m using card-mod nicely, but recently I had to try to use mod-card to customize a vertical-stack, but I got this error:
  • Custom element not found: mod-cardā€™
type: custom:mod-card
style:
  hui-vertical-stack-card: null
    #root > * {
    margin: 0px 0 0px 0;
  card:
    type: vertical-stack
    cards:
      - type: entity
        entity: sensor.processor_temperature
        icon: 'mdi:thermometer'
      - type: entity
      - type: entity
Your indentation is off. The card definition should be less indented as a whole.
Also check the docs regarding the new syntax if youā€™re using the latest version of card-mod.
I have a fairly complex UI for my irrigation system
Before I post any code and waste anyoneā€™s time I wanted to check if it is likely to be possible to solve my two small issues.
  1. Can the small ā€˜slider number balloonsā€™ be brought to the top?
  1. Is it possible to make the number always visible? Currently it disappears until the screen is refreshed or a slider is moved.
Thanks for any help and I am more than happy to post the code if it might be worthwhile.
please post the code
By all means if you think you might have an insight as to why I have these issues.
If you just want to see it, it is on my GitHub and Iā€™m happy to link to it.
But it is quite a lot of code to clog up this thread with just for interest.
Hello sorry for disturbing you, but i searched everywhere i didnt found any answer.
Where i have to copy the code to customize badges ? I dont find any code editor for badges.
Thanks a lot for helping
  1. Select your view with badges, switch to edit mode:
  2. Select ā€œRaw config editorā€:
  3. Scroll down to your view with badges, put required styles:
Ohhhh, Raw config editor ! This is what i missed.
Thanks a lot !!! :ok_hand:
Racking my brain on how I can use card_mod to move mini-media-players progress bar from the bottom, to the top of the player.
Heres what I have so far, but no dice:
card_mod:
  style:
    .mmp__container mmp-progress:
        .mmp-progress {
          top: 0px;
          bottom: none;
Anyone more experienced with CSS have any ideas?
Never mind, I got it to work by changing this:
          style:
                div.mmp-progress {
                  top: 0px;
                  bottom: unset;
hi, can you tell me how did you integrate the Vocolinc humidifier? I have the Mistflow, I have had it integrated before but after I had to reset it, Iā€™m just unable to add it again. Thanks!
Itā€™s not the vocolink humidifer that I integrated , itā€™s just the vocolink switch who control my basic humidifier for on or off.
Styling "restriction-card":
Vertical alignment of the ā€œlockā€ icon:
I found old post regarding "restriction-card".
There is another option to align the ā€œlockā€ icon for "multiple-entity-row":
    style: |
      div#overlay {
        align-items: center;
How it works - check the example below: there are 4 identical rows:
  • 2 rows with card-mod (1 with "secondary_info", 1 w/o it);
  • 2 rows w/o card-mod (1 with "secondary_info", 1 w/o it).
In all rows w/o card-mod the ā€œlockā€ icon is not vertically aligned.
type: entities
entities:
  - type: 'custom:restriction-card'
    style: |
      div#overlay {
    row: true
    card:
      type: 'custom:multiple-entity-row'
      entity: sun.sun
      entities:
        - entity: sun.sun
        - entity: sun.sun
          icon: true
        - entity: sun.sun
          toggle: true
      name: normal + card-mod
      show_state: false
      secondary_info: last-changed
    style: |
      div#overlay {
    row: true
    card:
      entity: sun.sun
      entities:
        - entity: sun.sun
        - entity: sun.sun
          icon: true
        - entity: sun.sun
          toggle: true
      show_state: false
    row: true
    card:
      entity: sun.sun
      entities:
        - entity: sun.sun
        - entity: sun.sun
          icon: true
        - entity: sun.sun
          toggle: true
      show_state: false
    row: true
    card:
      entity: sun.sun
      entities:
        - entity: sun.sun
        - entity: sun.sun
          icon: true
        - entity: sun.sun
          toggle: true
      show_state: false
Other styles - managed by theme variables:
For rows - check the example below:
  • 1st row - with default style;
  • other rows - with same card-mod style (blocked row, protected by PIN, w/o PIN).
type: entities
entities:
    row: true
    card:
      entity: sun.sun
    restrictions:
      block: true
    row: true
    card:
      entity: sun.sun
    style: &ref_style |
      :host {
        --restriction-lock-icon-size: 18px;
        --restriction-regular-lock-color: var(--accent-color);
        --restriction-success-lock-color: green;
        --restriction-lock-row-margin-left: 24px;
    restrictions:
      pin:
        code: 1234
    row: true
    card:
      entity: sun.sun
    style: *ref_style
    row: true
    style: *ref_style
    card:
      entity: sun.sun
For cards - check the example below:
  • 1st card - with default style;
  • 2nd card - with card-mod style.
cards:
  - type: custom:restriction-card
    card:
      type: entities
      title: Default styles
      entities:
        - entity: sun.sun
        - entity: sun.sun
  - type: custom:mod-card
    style: |
      restriction-card {
    card:
      card:
        type: entities
        title: Changed styles
        entities:
          - entity: sun.sun
          - entity: sun.sun
Using a decluttering template:
Since the "restriction-card" may be used in many places of your HA setup, it could be a good idea to use a "decluttering-card" for that (described here with examples).
Here is an upgraded version of the decluttering template - with "card-mod" support:
  decl_restriction_card_row:
    default:
      - VALUE_ROW: false
      - STYLE_CARD_ROW: ''
    card:
      type: 'custom:mod-card'
      style:
        restriction-card:
            'div#card': '[[STYLE_CARD_ROW]]'
              div#overlay {
                {% if [[VALUE_ROW]] == true %}
                {% endif %}
            restriction-card {
              --restriction-lock-icon-size: 16px;
      card:
        restrictions:
          pin:
            code: 1234
            text: Š’Š²ŠµŠ“ŠøтŠµ PIN Š“Š»Ń рŠ°Š·Š±Š»Š¾ŠŗŠøрŠ¾Š²ŠŗŠø
            retry_delay: 3
            max_retries: 3
            max_retries_delay: 10
        action: hold
        duration: 10
        row: '[[VALUE_ROW]]'
        card: '[[CARD_OR_ROW]]'
This template has 3 types of styles:
  • a style for vertical alignment of the ā€œlockā€ icon (see above);
  • other styles for the ā€œlockā€ icon (see above);
  • a style to be applied to a card or row (represented by STYLE_CARD_ROW input variable).
How to use the template:
  1. Default styles, no other styles are applied to the card or row:
    For rows:
type: entities
title: Default styles (rows)
entities:
  - type: 'custom:decluttering-card'
    template: decl_restriction_card_row
    variables:
      - VALUE_ROW: true
      - CARD_OR_ROW:
          entity: sun.sun
    variables:
      - VALUE_ROW: true
      - CARD_OR_ROW:
          entity: sun.sun
          entities:
            - entity: sun.sun
            - entity: sun.sun
              icon: true
            - entity: sun.sun
              toggle: true
          show_state: false
For cards:
variables:
  - CARD_OR_ROW:
      type: entities
      title: Default styles (card)
      entities:
        - entity: sun.sun
        - entity: sun.sun
  1. How to style a card inside the "restriction-card":
    Just place a style below the card definition (i.e. as a part of card definition):
title: Style as a part of card definition
cards:
    variables:
      - CARD_OR_ROW:
          type: entities
          entities:
            - entity: sun.sun
            - entity: sun.sun
          style: |
            ha-card {
              color: red;
    variables:
      - CARD_OR_ROW:
          type: entities
          entities:
            - entity: sun.sun
            - entity: sun.sun
          style:
            hui-text-entity-row:
                hui-generic-entity-row $: |
                  .text-content:not(.info) {
                    color: red;
  1. How to style a row inside the "restriction-card":
    There are 2 options:
  • Method 1 - define a style as a part of decluttering-card definition;
  • Method 2 - pass a style as an input variable.
Method 1:
Need to specify a full path to the row:
type: entities
entities:
    variables:
      - VALUE_ROW: true
      - CARD_OR_ROW:
          entity: sun.sun
    style:
      mod-card$.type-custom-mod-card restriction-card$:
        'div#card hui-text-entity-row$': |
          hui-generic-entity-row$: |
              color: red;
Method 2:
Need to specify a style as an input variable:
title: Style as an input variable
cards:
  - type: custom:decluttering-card
    variables:
      - VALUE_ROW: true
      - CARD_OR_ROW:
          entity: sun.sun
          name: style passed to decluttering
      - STYLE_CARD_ROW:
          hui-text-entity-row$:
                color: cyan;
    variables:
      - VALUE_ROW: true
      - CARD_OR_ROW:
          type: custom:multiple-entity-row
          entity: sun.sun
          entities:
            - entity: sun.sun
            - entity: sun.sun
              icon: true
            - entity: sun.sun
              toggle: true
          show_state: false
      - STYLE_CARD_ROW:
          multiple-entity-row$hui-generic-entity-row:
              state-badge {
                color: magenta;
              div.entity:nth-child(2) state-badge {
                color: red;
Method 2 may be used for styling cards too. But I would recommend to specify a style as a part of card definition (see above).
Custom background:
post
a1
a2
More examples are described here.
