Styling "hui-input-number-entity-row"
- entity row for "input_number"
This post is dedicated to styling an "input_number"
entity defined with a "box"
type:
input_number:
test_number:
min: ...
max: ...
step: ...
mode: box
icon: ...
If an "input_number"
entity is defined with a "slider"
type - then check this post for âslider entitiesâ.
Update (21.06.22): the post is updated with styles for MDC controls; old styles (see at the bottom of the post) do not work since 2022.3.
Warning: different browsers may display input_number
rows differently; here pictures from Chrome are provided by default.
Colored name:
Two methods are available:
â using a short â:host
â navigation;
â using a more detailed DOM navigation.
code
- type: entities
title: Colored name
entities:
- entity: input_number.test_number_2
name: Colored name (method 1)
card_mod: &ref_card_mod_red_text_host
style: |
:host {
color: red;
secondary_info: last-changed
card_mod: *ref_card_mod_red_text_host
name: Colored name (method 2)
card_mod: &ref_card_mod_red_text_dom
style:
hui-generic-entity-row $: |
.info {
color: red;
card_mod: *ref_card_mod_red_text_dom
How to style several rows:
Note that a common style may be overwritten for some particular entity.
code
- type: entities
title: Colored name for all entities
card_mod:
style:
.card-content:
div:
hui-input-number-entity-row $ hui-generic-entity-row $: |
.info {
color: orange;
entities:
name: Cannot be overwritten
style: |
:host {
color: red !important;
card_mod: &ref_card_mod_overwritten_text
style:
.info {
card_mod: *ref_card_mod_overwritten_text
name: Colored name (common)
Colored secondary_info:
code
- type: entities
title: Colored secondary_info for some entity
entities:
name: Colored secondary_info
card_mod:
style:
.info .secondary ha-relative-time {
color: orange !important;
card_mod:
style:
.info {
color: red;
But - the new style is working unstable in my setup (HA 2022.6, card-mod 3.1.5) - sometimes it is applied, sometimes notâŚ
code
- type: entities
title: Colored secondary_info for all entities
card_mod:
style:
.card-content:
div:
color: cyan !important;
entities:
name: Colored sec.info (common)
name: Overwritten color (unstable)
card_mod:
style:
Colored icon:
â using a CSS variable;
â using a CSS property with a detailed DOM navigation.
code
- type: entities
title: Colored icon for some entity
entities:
name: 'Colored icon (method #1)'
card_mod:
style: |
:host {
--paper-item-icon-color: red;
name: 'Colored icon (method #2)'
card_mod:
style:
state-badge {
color: red;
code
- type: entities
title: Colored icon for all entities
card_mod:
style: |
ha-card {
--paper-item-icon-color: cyan;
entities:
card_mod:
style: |
:host {
name: Colored icon (common)
Some other styles for an icon - resized icon, hidden icon:
code
- type: entities
title: Other styles for icon
entities:
card_mod:
style: |
:host {
--mdc-icon-size: 40px;
card_mod:
style:
state-badge {
display: none;
Colored value:
code
- type: entities
title: Colored value
entities:
card_mod:
style: |
:host {
--mdc-text-field-ink-color: red;
Colored UoM:
By default a UoM label is colored by â--secondary-text-color
â; you may specify any color or set it equal to â--primary-text-color
â.
code
- type: entities
title: colored UoM
entities:
- entity: input_number.test_value_uom
card_mod:
style: |
:host {
--secondary-text-color: red;
card_mod:
style: |
:host {
--secondary-text-color: var(--primary-text-color);
Colored fieldâs background:
code
- type: entities
title: Colored background
entities:
name: colored background
card_mod:
style: |
:host {
--mdc-text-field-fill-color: lightgreen;
Colored underline:
The underline had 3 possible states:
â a default (static) state;
â the input field is hovered by a mouse;
â the input field is selected by a mouse.
There are CSS variables for each state.
In the example below:
â the 1st row is modded by using these CSS variables;
â the 2nd row is modded by changing CSS properties with a detailed DOM navigation;
â the 3rd row has transparent underlines.
code
- type: entities
title: Colored underline
entities:
card_mod:
style: |
:host {
--mdc-text-field-idle-line-color: red;
--mdc-text-field-hover-line-color: cyan;
--mdc-theme-primary: magenta;
card_mod:
style:
ha-textfield $: |
.mdc-line-ripple::before {
border-bottom-color: red !important;
.mdc-line-ripple::after {
border-bottom-color: magenta !important;
name: no underline
card_mod:
style:
ha-textfield $: |
.mdc-line-ripple::before,
border-bottom-style: none !important;
Changing a padding around an input field:
code
- type: entities
title: padding
entities:
name: left & right padding = 0
card_mod:
style: |
:host {
--text-field-padding: 0px;
name: right padding = 0
card_mod:
style:
ha-textfield $: |
label {
padding-right: 0px !important;
Changing a width of the input field:
code
- type: entities
title: field width
entities:
name: custom (method 1)
card_mod:
style: |
:host {
--ha-textfield-input-width: 160px;
name: custom (method 2)
card_mod:
style:
ha-textfield $: |
input {
width: 120px !important;
Changing a padding around the UoM label:
code
- type: entities
title: padding for UoM
entities:
card_mod:
style: |
:host {
--text-field-suffix-padding-left: 0px;
--text-field-suffix-padding-right: 12px;
Wrapping a long name:
code
- type: entities
title: Wrapping a text for the name
entities:
name: long long long long long long long
card_mod: &ref_card_mod_wrapping_text
style:
.info {
text-overflow: unset !important;
white-space: unset !important;
card_mod: *ref_card_mod_wrapping_text
Hidden name:
â use a âblankâ name;
â hide the name.
code
- type: entities
title: Hidden name
entities:
card_mod:
style:
.info {
display: none;
Changed rowâs height:
code
type: entities
entities:
card_mod:
style:
ha-textfield $: |
.mdc-text-field {
height: 40px !important;
How to disable an input_number
row:
â the row is displayed as disabled;
â the row only has a read-only input field.
code
- type: entities
title: Locked input_number
entities:
- entity: input_boolean.test_boolean
name: Lock input_number
tap_action:
action: none
card_mod:
style: |
:host {
{% if is_state('input_boolean.test_boolean','on') %}
--mdc-text-field-ink-color: var(--disabled-text-color);
--mdc-text-field-idle-line-color: var(--disabled-text-color);
--paper-item-icon-color: var(--disabled-text-color);
pointer-events: none;
{% endif %}
tap_action:
action: none
card_mod:
style: |
:host {
{% endif %}
- type: section
label: with UoM
tap_action:
action: none
card_mod:
style: |
:host {
--secondary-text-color: var(--disabled-text-color);
{% endif %}
Short list of CSS variables available for âtextfieldâ control:
Old styles - not valid since HA 2022.3
Colored value:
Styling is done like for "input-text"
entity row - check this description.
Colored background:
Aligned value:
Colored underline:
Disabled control:
type: entities
entities:
tap_action:
action: none
card_mod:
style: |
:host {
--paper-input-container-color: var(--disabled-text-color);
--paper-input-container-input-color: var(--disabled-text-color);
{% endif %}
Also, you may remove color
options to make the row clearly visible but âread-onlyâ.
More examples are described here.
