Card mod: Change card (text) color based on state
Hi all,
trying to make either the text or card color change to highlight when the humidity is too high. I was browsing around and found the cardmod but can’t seem to make it work. I’m not very proficient at Yaml yet can someone please verify / point out what I did wrong?
(Device: Sonos temp sensor)
Entity: sensor.temp_sensor2_humidity_2
Value: 60
type: entities
entities:
  - entity: sensor.temp_sensor2_humidity_2
  - entity: sensor.temp_sensor2_temperature_2
title: babyroom
show_header_toggle: false
footer:
  type: graph
card_mod:
  style: |-
    ${ if ( sensor.temp_sensor2_humidity_2 =>'60') {
      'ha-card {color: red;}'
    } else {
Following change both the background color and text color of the entity.
Ok, here it is:
type: entities
entities:
    style: >
      * {color: {% if states('sensor.temp_sensor2_humidity_2')|int(0) >= 60 %}yellow{% else %}navy{% endif %};}
title: babyroom
footer:
  type: graph
style: |
  ha-card {
    background: red;
    {% else %}
    background: aqua;
    {% endif %}
Of course, this is just example, you should choose what you really want to change.
Bets regards!
