Is there anyone out there who is savy with CSS/style elements and would be able to tell me what I need to add under ‘style’ in order to remove the white background from the entity_picture on the Map card?
I can make the changes in Chrome Inspector but struggling in regards to adding this as a ‘style’ element
For other people who wan’t to change the map layout. This works for the default lovelace map-card.
To change layout of the marker use the extra javascript module card-mod.
To install go to
Further instructions read there to install etc. To add a use full marker create a person with a tracker (the person can be a person or a device). Add a custom marker via customization in your configuration.yaml.
person.[something]:
entity_picture: /local/[something in your www folder in your config folder of HA]
details on custimazations for home assistant:
To create a special marker in your card add this below your title in the code of the card:
