Some Help i could use if possible…
sofar i did build this piece of code to enable - disable scripts
and use actions on it…
type: vertical-stack
cards:
- type: horizontal-stack
cards:
- type: tile
entity: automation.lamellen_open
hide_state: false
vertical: false
show_entity_picture: true
tap_action:
action: perform-action
perform_action: automation.trigger
entity_id: automation.lamellen_open
skip_condition: true
icon: mdi:script-outline
icon_tap_action:
perform_action: automation.toggle
features_position: bottom
card_mod:
style: |
ha-state-icon { color: {{'yellow' if
is_state('automation.lamellen_open', 'on') else 'red'}};
margin-top: -15px;
ha-card {
border: none !important;
--tile-color: transparent !important;
height: 40px !important;
- type: tile
entity: automation.lamellen_dicht
hide_state: false
vertical: false
tap_action:
entity_id: automation.lamellen_dicht
icon_tap_action:
card_mod:
style: |
ha-state-icon {
color: {{'yellow' if is_state('automation.lamellen_dicht', 'on')
else 'red'}};
margin-top: -15px;
ha-card {
- type: tile
entity: automation.lamellen_46
hide_state: false
vertical: false
tap_action:
entity_id: automation.lamellen_46
icon_tap_action:
card_mod:
style: |
ha-state-icon {
color: {{'yellow' if is_state('automation.lamellen_46', 'on') else
'red'}};
margin-top: -15px;
ha-card {
results:
Now due the small height i use…
ive managed to get up higher the icons…
but im failing to raise the content …
and to get the content closer by the icon to the left…
is this fixable?
or any other guru has an other solution to add this all in just on card?
any suggestions are welcome…
thanks in advance
greetz T…
