Card-mod - losing descenders - how to change row height?
Hopefully a simple one to someone who knows! I’m losing the descenders on the letters p and y on this card so I think I need to change the row height. I’ve read through loads of posts and tried lots of things but I still can’t figure it out. (Sorry, I’m not good at CSS type things!)
This is my lovelace card:
type: vertical-stack
cards:
  - type: entities
    entities:
      - entity: sensor.wupws_temp
      - entity: sensor.outside_side_door
      - entity: sensor.kitchen
      - entity: sensor.velux_sensor_temperature
      - entity: sensor.bedroom
      - entity: binary_sensor.gates
      - entity: switch.gate
        name: Open/close the Gates
      - entity: cover.velux_window
      - entity: cover.velux_window_3
      - entity: cover.velux_window_2
      - entity: script.sunny_day
      - entity: script.close_blinds_kitchen_halfway
        name: Kitchen blinds halfway
    card_mod:
      style: |
        ha-card {
          font-size: 26px;
This is what it looks like:
How can I fix this please?
Loosing them since font-size is too large, letters are clipped inside low rows.
Either to reduce a font-size or increase a rows height.
See, anyway font size is different on your card - compare entities’ names & “Run” buttons.
Thanks. Yes, this dashboard is for a wall-mounted tablet so I want the letters to be large for visibility.
Could you help me with the exact syntax for increasing the row height?
  1. Companion App (at least for iOS) allows to scale UI - including font-size.
    Check settings in the App.
  2. Same as for a browser if you are using it as a client - you may scale a page.
    (imho not always working correctly)
  3. It is possible to manage rows’ height (as well as margins between them) - go to the dedicated card-mod thread → 1st post → link at the bottom → find a “How to manage a row’s height” (called smth like this) para.
Better to discuss similar issues in that thread instead of creating new threads (easier to find info + other people may join).
For details please continue this discussion there.
