Card_mod problem after upgrading Home Assistant to 2023.10.0
I’ve upgraded Home Assistant to 2023.10.0 and I lost a couple of views of my Dashboard. Trying to rebuild them right now, but running into a card_mod problem which was not there before the upgrade!
See screenshot below, I’m getting the error message: property card_mod is not allowed! What am I doing wrong?
And the configuration.yaml file I’ve the following:
And I’ve upgraded the card_mod.js file to the latest version as well! What am I doing wrong?
style should be indented under card_mod. So:
card_mod:
  style: |
And the url should be “/local” not “/config/www”.
Thanks for the suggestions, but unfortunately that doesn’t solve the problem, see screenshots.
Other suggestions ?
And where should the card_mod.js file be stored? Currently I’ve it in: /config/www/community/lovelace-card-mod/card-mod.js
If your config works, and this is only about the error messages in the vscode addon, i think you have to live with it.
Nope, the config doesn’t work. The text on the button is not displayed at a smaller font size, unfortunately
Hi dude, did you managed to solve this?
I was on the same boat and noticed that if you got card-mod installed from HACS in the card page on HACS there is a little step by step config tutorial where it says that you must specify the path like this:
frontend:
  extra_module_url:
      - /hacsfiles/lovelace-card-mod/card-mod.js
I’ve already done this way and it worked.
Cheers!
