Card-mod question - how to make media query work with animation of state-icon
Hi all:
I’m fighting with some tricky CSS styling issue with card-mod, I’d like apply to a state-icon (in a PE card) so that:
  1. Animation works on the SVG icon
  2. The background hides with screen size is below 750px
I can achieve either goal easily but when I put them together, looks like the selector always only take what’s defined first, for example with the code below animation and color work, but media query style doesn’t apply:
  - type: state-icon
    <<: *toggle_actions
    entity: switch.kitchen_aquarium_plug
    title: Pump
    style:
      <<: *icon_style
      top: 18%
      left: 40%
    card_mod:
      style:
        state-badge:
            ha-state-icon:
                ha-icon:
                    ha-svg-icon {
                      {% if is_state(config.entity, 'off') %}
                        color: var(--error-color);
                        animation: none;
                      {% else %}
                        color: var(--running-color);
                        animation: wave 5s linear infinite;
                      {% endif %}
                    @keyframes wave {
                      0% { transform: rotate(0deg); }
                      20% { transform: rotate(15deg); }
                      60% { transform: rotate(-15deg); }
                      100% { transform: rotate(0deg); }
          @media (max-width: 750px) {
            :host {
              /* This targets the outer state-icon element for small screens */
              background-color: transparent !important;
              backdrop-filter: none !important;
I’m no expert of CSS and already tried more than 10 ways suggested by ChatGPT without luck.
So would like to confirm here if this is even possible with css?
seems plausible for me - have you had a look at the results within the browser tools to inspect the css code that results?
cheers Franky
Thanks for your reply!
I’m not really good at CSS and HTML, would appreciate some hint on where to look.
So what I notice is that if I only keep the ha-svg-icon and animation part, it works.
Same if I only keep the @media (without $: |) it also works. Put them together it doesn’t work :frowning:
Two things to try:
  1. change
        state-badge:
to
        state-badge $:
  1. change
            :host {
to
          :host {
Thank you for your help!
:pray:
