I do not know where you got that code from.
Try this code: https://github.com/thomasloven/lovelace-card-mod/wiki/Theme-cookbook#compact-header
ok i copied that, but now the header is compact and at top again
Did you uncomment the line that moves it to the bottom?
Thats like this right?
card-mod-root-yaml: |
paper-tabs$: |
.not-visible {
display: none;
/*Uncomment this if you want the header on the bottom
#selectionBar {
bottom: unset !important;
ha-app-layout$: |
/* This corrects top padding for the view. */
#contentContainer {
/* Change this to 0px if you want the header on the bottom */
padding-top: 48px !important;
into this:
paper-tabs$: |
.not-visible {
display: none;
selectionBar {
ha-app-layout$: |
#contentContainer {
padding-top: 0px !important;
No, change the whole thing.
Sorry, but i dont understand
paper-tabs$: |
.not-visible {
display: none;
/*Uncomment this if you want the header on the bottom */
selectionBar {
ha-app-layout$: |
#contentContainer {
Thats the same like i did right?
By uncomment , they mean ger rid of the #
Hereās the whole thing:
# Header
paper-tabs$: |
.not-visible {
display: none;
#selectionBar {
ha-app-layout$: |
#contentContainer {
ha-button-menu$mwc-menu$mwc-menu-surface$: |
.mdc-menu-surface {
margin: 10px;
box-shadow: var(--ha-card-box-shadow, 0px 2px 1px -1px rgba(0, 0, 0, 0.2), 0px 1px 1px 0px rgba(0, 0, 0, 0.14), 0px 1px 3px 0px rgba(0, 0, 0, 0.12));
/* This hides the unused portion of the header. */
app-toolbar {
height: 0;
/* This forces background-color and text-color. */
.edit-mode, app-header, app-toolbar {
background-color: var(--primary-background-color) !important;
color: var(--primary-text-color) !important;
/* Uncomment this if you want the header on the bottom
app-header {
top: calc(100vh - 60px) !important;
bottom: 0 !important;
transform: unset !important;
hui-masonry-view {
padding-bottom: 60px !important;
/* This gives the header in edit mode a different look from the standard header. */
app-header.edit-mode {
border-bottom: 2px var(--primary-color) solid;
padding-bottom: 10px;
/* Make the color of the plus white instead of black. */
#add-view ha-svg-icon {
color: #EEE !important;
/* Bring voice button back down */
app-toolbar:not([class="edit-mode"]) mwc-icon-button[label] {
top: 0;
right: calc(48px * 1);
z-index: 2;
position: absolute;
/* Bring help button back in */
a[href="https://www.home-assistant.io/lovelace/"] > mwc-icon-button {
right: calc(48px * 2);
position: absolute;
z-index: 2;
/* Bring close button back in */
mwc-icon-button[title="Close"] {
top: 0;
left: 0;
position: absolute;
z-index: 2;
/* Bring add view button back in */
mwc-icon-button#add-view {
position: fixed;
right: 48px;
/* Bring edit UI overflow menu back in */
ha-button-menu {
top: 0;
right: 0;
z-index: 2;
position: absolute;
/*Uncomment this out to hide the overflow menu
display: none;
/* Hide the title */
app-toolbar > [main-title] {
display: none;
/* Hide buttons that are taking up space, but invisible */
menu-button[style="visibility: hidden;"] {
display: none;
/* Bring sidebar button back in */
ha-menu-button {
z-index: 2;
top: 24px;
/* Set margin on left to be smaller,
and set the bar color to be the primary color
instead of white */
paper-tabs {
--paper-tabs-selection-bar-color: var(--primary-color) !important;
margin-left: 48px !important;
/* When not in edit mode, shrink the left margin */
app-toolbar:not(.edit-mode) > div > paper-tabs {
margin-left: 6px !important;
/* Color selected tabs */
paper-tab[aria-selected="true"] > ha-icon {
paper-tab[aria-selected="true"] {
/* Styles for mobile */
@media (orientation: portrait) {
/* Hide sidebar button and keep room for the overflow menu button */
paper-tabs {
margin-left: 5px !important;
margin-right: 48px !important;
/* Hide voice button */
mwc-icon-button[label="Start conversation"] {
display: none !important;
/* Hide sidebar button */
ha-menu-button {
/* Make help button have contrast */
app-toolbar a {
# Badges and columns
card-mod-view-yaml: |
hui-masonry-view$: |
mwc-fab[title="Add Card"] {
bottom: 96px !important;
Also I just realized someone mightāve modded maykarās theme, or used an old version of mine.
its still not at the bottom, been trying for days to get what i want but i dont understand parts of the code
kTibow, if i copy exact your code, will it be at the bottom?
Nobody can share there minimum code, just to get it to the bototom
Itās hard to make it be at the bottom without making it be compact. It should be at the bottom.
I copied your code now, its not at the bottom, its at the top
Follow the instructions in the comments. If it says āuncomment thisā, remove the whole line of text, not just the comment part.
Can you please share a code that is already uncommented?
Iām not sure what the get rid of
So i have a code that does put it to the bottom?
Are you using a translator? Anyway, Iāll help you just because, even though itās a small task:
compact-header:
card-mod-theme: compact-header
# Header
paper-tabs$: |
.not-visible {
display: none;
#selectionBar {
ha-app-layout$: |
#contentContainer {
.mdc-menu-surface {
margin: 10px;
app-toolbar {
height: 0;
app-header {
hui-masonry-view {
top: 0;
z-index: 2;
position: absolute;
position: absolute;
z-index: 2;
top: 0;
left: 0;
position: absolute;
z-index: 2;
position: fixed;
right: 48px;
ha-button-menu {
top: 0;
right: 0;
z-index: 2;
position: absolute;
display: none;
display: none;
display: none;
ha-menu-button {
z-index: 2;
top: 24px;
instead of white */
paper-tabs {
paper-tabs {
ha-menu-button {
app-toolbar a {
Hope this worksā¦
ok its at the bottom, thank you for that, but its not good yet
some stuff on my phone, is hidden behind the bottom header
I want to hide 2 tabs from that header too
and the top header should be visible so i can add messages in there
Sorry i keep asking help, but CH was so much easier
and yes i used a translator, which said to get rid of the # but that wasnt enough
Can you send a screenshot? You can already hide tabs based on users:
Can you give an example of what kind of messages you want?
When i hide the tab from users, they wont be visible anymore, i just dont want them to show in the headerā¦ they do have to able to be reached
For the messages, with CH i had the space to show following messages:
- Current Temperature
- When washing machine is ready
- Welcome messages
It was using a vertical marquee
What should be the toggle between being hidden and unhidden?
I can try to whip something up to keep the header not compact but at the bottom.
- Yes, having the header at the bottom without it being compact is a good idea
- No, having the header at the bottom without it being compact isnāt a good idea
Hiding them as @KTibow mentions using Visability only hides them in the header. They are still reachable. For example, I have views for my Roku remotes. I hide the tab (at the top in my case) but a long press on a button setup for on/off of the TV will take me to the remote.
