šŸ”¹ Card-mod - Super-charge your themes!
I canā€™t find Card-Mod on HACS?
Under the frontend section, show a screenshot.
Is it called card-tools?
Thatā€™s a separate thing. Itā€™s card-mod.
Sorry Its says ā€˜Geen repositoriesā€™ (no repositories)
Can you send a screenshot?
It will say that if searching for it and it is already installed
Sorry Itā€™s in dutch. Tried both in intergrations and frontend. Iā€™m using a couple of hacs plugins already.
Does it show up in the list of already installed stuff in frontend?
No. I canā€™t find anything anymore. It has something to do with my repositories?
Shows up here:
(bottom right)
This is all i have.
I just removed card-tools and i canā€™t find it either.
Do you see any notices on the home page of HACS?
No. looks normal. I just removed hacs intergration, made a new API key from Github and added Hacs again via Setting>>Intergrations
Odd. Try restarting HA.
Doesā€™nt work. I donā€™t have any custom repositories.
Please make a new topic, not related to card-mod theming.
Press the ā€˜+ā€™ button on the right bottom.
OMG. There was a windows in front of it. I used hacs for a while but totally missed the +. Sorry for bothering.
I read that Card-mod could be used to create the same effect as Custom Header ā€œCompact modeā€ā€¦ so, I can have a compact header at all times.
I am not sure how to do that using my existing theme called, ā€œtechleechā€. My understanding is I can use the Compact header code from the link below:
I tried appending this code in the file below (after all color definitions); then, select the ā€œTechleechā€ theme in Home Assistant. However, my header still looks the same.
\config\themes\techleech\techleech.yaml
Could someone please tell me the easiest way to get Home Assistantā€™s header more compact using card mod? Considering that Iā€™m already using a theme.
