One possibility is that you still need to reload your theme.
Another possibility is that you literally just pasted all the code from compact header at the bottom of your theme without any changes at all. If so then that is the problem.
Remove the very first compact-header: line from what is shown on the wiki, so as to make that code part of the theme defined before it, and change the card-mod-theme value to match the the theme key name inside the yaml, probably techleech. If there is more than one theme inside techleech.yaml, such as if it defines a dark and light pair, then you need to append code to each, with the only difference being the card-mod-theme line.
Hope this helps. If not, we would probably need to see the exact contents of your theme file.
Ok im almost thereā¦
I managed to get the chevrons away + hiding some tabs, and let it stay at the bottom
However Theres some space above the header, i marked it red.
It hides the bottoms after it, and the text from the header jumps up and down when i scroll
How do i get rid of that space?
how do i get the space back up on top to show me messages? (its the app- toolbar right?)
Vote āYes, having the header at the bottom without it being compact is a good ideaā here:š¹ Card-mod - Super-charge your themes!
Iām sorry that I donāt have more time, and I know that itās terrible not to be listened to (like the one time I made a feature request for a toilet domain), but if this gets enough votes that keeping the message space is important Iāll see what I can do.
Iāve been working on transitioning from custom-header to card-mod theming and have it pretty much identical. But Iām struggling with header background color opacity. For reference, Iāve applied this to my theme.
Iāve been using chrome dev tools and see app-header, app-toolbar background-color css, but thereās also the issue of expanding the background image.
Iāve scrolled down slightly to show what Iām talking about.
I have tried copying your code and the blurred effect, looks great. Only issue is the popup header doesnāt seem to adopt the style. Here is what it looks like:
Hi in my post I stated that I didnāt get it to work. So the headers in my more info popups are the same as the header color, just like on yours. I suspect because the code is different on mobile, because of media query. So when the display size is narrower it gets the header color. Look at my posts there. Though Iām not sure thatās cause.
I decided to just keep it that way and have since gotten used to it on mobile.
I guess Iām stupid
I created a new theme called compact-header.yaml, copied the code, did the reload of the themes and used this new theme in my settings.
but the header is not changing.
Hi, I tested the art-nouveau theme and it looks great!
One minor problem is, that the pictures displayed by the badges are not centered anymore.
Example:
