🔹 Card-mod - Super-charge your themes!
Sure. Here are three cards (using the visual editor):
type: tile
entity: light.sofa_lights
card_mod:
  class: light
type: tile
entity: switch.ensuite_towel_rail
card_mod:
  class: switch
type: tile
entity: switch.irrigation
card_mod:
  class: water
Page theme set to ‘test’.
Result:
Unfortunately this way may be used in some cases only - like “ha-card → element_1 → $ → element_2” but not in “ha-card → for each element_1 → …”.
Compare these:
    ha-card.class_2>.card-content>div>:first-child $ hui-generic-entity-row $: |
          state-badge {
            color: cyan;
    ha-card.class_2>.card-content div>:first-child $ hui-generic-entity-row $: |
      state-badge {
        color: cyan;
There is only ONE difference - a “whitespace” is used instead of “>” - which in THIS particular case must be same, but a style with “>” does work, with “whitespace” does not.
That particular case was about synthetic situation “Entities card with many rows, change icon color for each row”.
Even this simplest does not work (styling a header for Glance card), so I cannot understand why that “>” style works:
    ha-card.class_1 $: |
      .card-header {
        color: cyan !important;
        font-size: 40px !important;
        letter-spacing: 10px !important;
Also, please check if your method works with OMITTED elements in the path - i.e. when you do not have to write down ALL consecutive elements in the path.
I was sure till now that using variables is the only working way. You demonstrated an alternative - but it has some limitations…
Yeah, it won’t work for theming multiple element 1s, you’d have to specify for each. I don’t use entity cards with multiple rows so can see how that would be a pain.
Have tried omitting elements in the path and it doesn’t work - you have to do the whole path.
Can you give me an example of you using class-defined variables to style a shadowDOM element?
A bit later I’ll post kind of tutorial dedicated to this staff.
Gonna refer your experience too.
Using classes:
The simplest example:
Theme:
  card-mod-card-yaml: |
      ha-card.class_0 {
        border: solid 1px #ff0000;
        background-color: lightblue;
Cards:
  - type: vertical-stack
    cards:
      - type: history-graph
        title: class_0
        entities:
          - sun.sun
        card_mod:
          class: class_0
        title: title
        entities:
          - sun.sun
      - type: entities
        title: class_0
        entities:
          - sun.sun
        card_mod:
          class: class_0
      - type: entities
        title: title
        entities:
          - sun.sun
If needed to style elements inside shadowRoot - a possible way is defining variables.
Consider this Entities card:
type: entities
entities:
  - sun.sun
  - sensor.processor_use
  - input_number.test_number
  - input_select.test_value
  - input_boolean.test_boolean
and you want to set colors for icons differently for odd & even rows.
Theme (only related styling, no “class_0” code):
    .card-content:
      div:nth-child(n):
          state-badge {
            color: var(--class_2-color-odd,orange);
      div:nth-child(2n+1):
          state-badge {
            color: var(--class_2-color-even,lightgreen);
      ha-card.class_2 {
        --class_2-color-odd: red;
        --class_2-color-even: cyan;
        background-color: yellow;
where “orange” & “lightgreen” may be replaced by a default (for now!!!) “–paper-item-icon-color”.
Here some variables are defined in some “classy” ha-card → then used inside some internal shadowRoot. Be aware of defining default values for cards of different classes.
Cards:
    cards:
      - &ref_entities_diff_domains
        type: entities
        entities:
          - sun.sun
      - <<: *ref_entities_diff_domains
        card_mod:
          class: class_2
        card_mod:
          class: class_0
where the 3rd card has applied “class_0” styles (described above).
One more example - styling a card’s header.
Due to some recent changes the “.card-header” element is located inside shadowRoot for some cards (like “history-graph”, “glance”). So, the theme must define some “classy” style for “.card-header” inside shadowRoot and directly inside ha-card.
Theme:
      .card-header {
        color: var(--class_1-color,var(--ha-card-header-color,--primary-text-color)) !important;
        font-size: var(--class_1-font-size,var(--ha-card-header-font-size, 24px)) !important;
        letter-spacing: var(--class_1-letter-spacing) !important;
      ha-card.class_1 .card-header {
        color: var(--class_1-color);
        font-size: var(--class_1-font-size);
        letter-spacing: var(--class_1-letter-spacing);
      ha-card.class_1 {
        background-color: lightgrey;
        --class_1-color: magenta;
        --class_1-font-size: 10px;
        --class_1-letter-spacing: 10px;
Here all described cards together:
code
theme: Backend-selected
path: classy-shadowroot
badges: []
title: classy shadowroot
cards:
    cards:
        title: class_0
        entities:
          - sun.sun
        card_mod:
          class: class_0
        title: title
        entities:
          - sun.sun
      - type: entities
        title: class_0
        entities:
          - sun.sun
        card_mod:
          class: class_0
      - type: entities
        title: title
        entities:
          - sun.sun
    cards:
        type: entities
        entities:
          - sun.sun
        card_mod:
          class: class_2
        card_mod:
          class: class_0
    cards:
        title: class_1
        entities:
          - sun.sun
        card_mod:
          class: class_1
        title: title
        entities:
          - sun.sun
    cards:
      - type: entity
        entity: sun.sun
        card_mod:
          class: class_1
      - type: entity
        entity: sun.sun
    cards:
      - type: glance
        title: class_1
        <<: &ref_glance_card
          entities:
            - entity: sun.sun
          show_name: true
          show_icon: true
          show_state: true
        card_mod:
          class: class_1
      - type: glance
        title: title
        <<: *ref_glance_card
    cards:
      - type: entities
        entities:
          - entity: sun.sun
        title: class_1
        card_mod:
          class: class_1
      - type: entities
        entities:
          - entity: sun.sun
        title: title
    cards:
      - type: entities
        title: class_1
        card_mod:
          class: class_1
        entities:
          - type: custom:hui-element
            <<: &ref_hui_element
              card_type: entities
              entities:
                - entity: sun.sun
            title: title
            <<: *ref_hui_element
            title: class_1
            card_mod:
              class: class_1
      - type: entities
        entities:
          - entity: sun.sun
        title: title
What I tried and failed:
      .card-header {
    ha-card.class_2 .card-content:
      div:nth-child(n):
          state-badge {
            color: cyan;
          state-badge {
            color: red;
And check an alternative solution provided by @ajoyce (theme, test cards):
Here a path should be defined as
    ha-card.light>div.tile>div.content>div.icon-container>ha-tile-icon$: |
      div.shape::before {
        opacity: 0
Unfortunately this method has some limitations (here, here) - and anyway it could be a better solution in some cases than using variables.
talking about classes, I just noticed this difference beween Safari and Chrome
in my main theme I set ha-card-border-radius: 0px
and Safari listens to that everywhere, also in the footer buttons, because of:
    hui-buttons-header-footer $ hui-buttons-base $ : |
      .ha-scrollbar {
        justify-content: space-evenly;
        height: 50px;
        align-content: center;
        margin: -8px 0px 0px 0px;
        --ha-chip-background-color: var(--primary-color);
        --ha-chip-text-color: var(--card-background-color);
        --paper-item-icon-active-color: red;
        --secondary-text-color: var(--card-background-color);
    hui-buttons-header-footer $ hui-buttons-base $ .ha-scrollbar ha-chip:
        .mdc-chip {
          border: 1px solid green;
          border-radius: var(--ha-card-border-radius);
However, Chrome does:
and, upon checking the inspector I see
Scherm­afbeelding 2023-03-18 om 13.10.10
which apparently is not applying the card-mod…
changing that manually to
Scherm­afbeelding 2023-03-18 om 13.10.16
indeed results in
in Chrome now also…
Is my class not correct? Why the difference between Safari and Chrome…?
I also tested with:
        .mdc-chip {
          border-radius: var(--ha-card-border-radius) !important;
but the makes no difference
card-mod theme for chip buttons
  card-mod-row-yaml: |
    hui-buttons-base $: |
      ha-assist-chip {
        border: 1px solid red;
        border-radius: 4px;
before 2023.12, for a footer
        .mdc-chip {
          border: 1px solid red !important;
          border-radius: 4px !important;
I can confirm I see the correct border-radius on iOS app also.
I’ve just checked Firefox latest browser, and that also does not apply the mod, and shows rounded corners…
even if I use
border-radius: 0px !important;
they dont apply border-radius
note they DO apply the border, so the path to the element is correct
Chrome does have some other issues, in showing the view tab icons correctly…
where both Safari and Firefox (and the iOS app) correctly show this:
but that was not the reason to post this…
Create a test theme and copy / paste my code - if it works?
uhm, not sure what you mean?
I have the exact same code? (besides the border-radius obviously )
I mean - with only this style (just in case).
My code exactly.
Wait…
        .mdc-chip {
this does work after all…
After the edit and addition of the !important, I had refreshed the view, in stead of reloading the theme…
doing so now shows me the squared corners!
So, Safari does not require the !important, nor does the iOS App (which essentially is a Safari browser), but Chrome and Firefox do…
since we’re on this button footer modding…
it’s all about these
    footer:
      type: buttons
      entities:
        - entity: input_boolean.loop_sound_bite
          name: Loop Soundbite
        - entity: script.play_sound_bite
          name: Speel soundbite
          icon: mdi:play
and, I really want to change the icon based in state of the config.entity.
when I used custom:button-card, I used:
              icon: >
                [[[ return (entity.state === 'on') ? 'mdi:stop' : 'mdi:play' ]]]
so I tried to set that mod on host
        card_mod:
          style: |
            :host {
              --card-mod-icon:
                {% if states(config.entity) == 'on' %} mdi:stop
                {% else %} mdi:play
                {% endif %};
but see no change. Is there some undocumented option to change those entity (script) icons in a footer button?
Cannot be used here.
type: entities
title: footer
entities:
footer:
  type: buttons
  entities:
    - entity: sun.sun
      show_name: true
      show_icon: true
    - entity: sun.sun
      show_name: true
      show_icon: true
    - entity: input_boolean.test_boolean
      show_name: true
      show_icon: true
    - entity: sun.sun
      show_name: true
      show_icon: true
card_mod:
  style:
    hui-buttons-header-footer $ hui-buttons-base $ .ha-scrollbar:
      ha-chip:
          .mdc-chip {
          ha-chip:nth-child(3) {
            {% if is_state('input_boolean.test_boolean','on') %}
            --ha-chip-background-color: lightgreen;
            {% else %}
            --ha-chip-background-color: cyan;
            {% endif %}
Actually, this is a bit an off-topic here, not exactly related to themeing.
indeed, moving to card-mod please
if you use thumbing like:
DONT UPDATE TO 2023.4 beta, because it will render
o and, btw, on button-card, see: Lovelace: Button card - #6829 by Mariusthvdb
Editing the header bar to semi transparent is failing now, too. Even with the new 3.2.1 update.
  card-mod-root: |
    app-header {
      background: var(--ha-card-background) !important;
    app-toolbar {
      background: transparent !important;
This worked for ages now. So I hope it’s correct ^^
Ah and this for more understanding of my doing:
  ha-card-background: "rgba(0, 0, 0, 0.5)"
the new card-mod did fix the main issue probably, but the mods on the card-mod-sidebar-yaml: no longer work.
update
well, they do card-mod-sidebar-yaml no longer works · Issue #264 · thomasloven/lovelace-card-mod · GitHub
but things changed in HA see:
so, for the regular notification badge, we need to add a default ,248px like:
      a[data-panel='ui-familie'] paper-icon-item:after {
              content: "{{states('sensor.family_home')}}";
              left: calc(var(--app-drawer-width,248px) - 44px);
              position: absolute;
              min-width: 20px;
              box-sizing: border-box;
              border-radius: 50%;
              font-weight: 400;
              background-color: {{states('sensor.presence_color')}}; /*var(--accent-color);*/
              line-height: 20px;
              text-align: center;
              padding: 0px 6px;
              color: {{'saddlebrown' if states('sensor.presence_color') == 'gold' else 'ivory'}};
              /*var(--text-accent-color, var(--text-primary-color));*/
              font-size: 14px;
and that brings back the notifications:
however, collapsing the menu changes css to a fixed 26px as you can see in the Inspector screenshot, and I’ve not found a way yet to mimic that in the mod. Or find a conditional on the menu being collapsed or not
Hi , something verry simple, i used before Kios Mode, to hide the top bar, but it doesnt work anymore on 2023.4, seems card mod can do it too . i use google dark theme mod, i did this …
Google Dark Theme:
  card-mod-theme: Google Dark Theme
  card-mod-root: |
    app-header {
      display: none;
  ha-card-border-color: rgba(0,0,0,0) ## transparent
  # Header:
  app-header-background-color: rgb(23, 23, 23)
  app-header-text-color: rgb(198, 203, 210)
  app-header-selection-bar-color: var(--primary-color)
  app-header-edit-background-color: rgb(136, 136, 136)
  # Main Interface Colors
But i still have the top bar? what am i missing? i added that card-mod-root to it above
I had the header moved to the bottom, but after today’s HA 2023.4 update, the header moved back to the top.
Any idea how to fix this?
I had my fun with transparency for quite some time now. Until 2023.4.0b0 in this case.
First some material I use right now: GitHub - dreimer1986/yourname_card_mod: Home Assistant theme - A dark, electric blue theme that reminds the movie Your Name.
This is a modified yourname theme for use with CardMod and Vilhelm’s Animated Backgrounds (with some 2023.4.0 fixes I hacked together here WARNING: 2023.4.0b0 or newer break Animated Background · Issue #56 · Villhellm/lovelace-animated-background · GitHub)
  1. I am open for any kind of suggestion of course. (But better over there on Github as I don’t wanna hijack this thread)
  2. Look closely on the animated pics I added. You can see the sidebar is a mixture of darker transparent buttons and a less transparent rest. This is the goal I want back…
As CardMod seems to have broken down quite a bit, I decided to get some stuff fixed with a style JS: https://raw.githubusercontent.com/dreimer1986/yourname_card_mod/master/www/styles.js
Header and Lovelace background are fine again, but sidebar is still funny. I got a suggestion from BramKragten how to fix it and it indeed does SOMETHING, just not what I want. The fix in the script casues one layer to vanish as the whole sidebar gets lighter. But there is one layer I cannot find and it is NOT transparent. This can be seen fine when the site loads up after Cache wipe. Sidebar has some dark color and the rest is way lighter. Sadly I cannot make a pic @ home as my PC is too fast, I saw this at work… Thus the current result is:
Here for comparison the same without setProperty("–mdc-theme-surface", “transparent”)
It’s darker.
Now to the final part… HELP!!! What did I miss in all my mess? Why is this thing not transparent? What layer did CardMod make vanish here and now fails to do?
