Does Compact-Header still work on HA 2023.4.0?
This following code in my theme.yaml doesnāt do jackshit
ios-dark-mode:
# Global
card-mod-theme: ios-dark-mode
card-mod-root-yaml: |
ha-menu-button {
display: none !important;
@media (orientation: portrait) {
a.menu-link[target="_blank"], ha-button-menu, [main-title] {
display: none;
paper-icon-button[icon="paper-tabs:chevron-right"] {
display: none;
paper-icon-button[icon="paper-tabs:chevron-left"] {
display: none;
I was able to fix that, using above suggestion for replacing āapp-headerā with ā.headerā, āapp-toolbarā with ā.toolbarā, and some more adjustments.
Here is my full theme configuration, in case anyone want to compare.
thanks for noticing that, I hadnāt, because my existing theme mods on those app-header and app-toolbar still work. which is remarkable?
/* Set the toolbar background. */
app-header, app-toolbar {
background: {{'radial-gradient(var(--primary-color),var(--card-background-color))'
if states('input_select.theme')|regex_search('(ight|Dark|Matrix)')
else 'var(--primary-color)'}};
color: var(--text-primary-color);
ive check and moved to:
.header, .toolbar {
and yes, that works also
huh?
need to check if the main settings also have changed:
app-header-background-color:
app-header-text-color:
app-header-edit-background-color:
for that matterā¦ no, they havent: frontend/src/resources/styles.ts at 81ebdf1448ab25689736ad59e5c9012e971280d1 Ā· home-assistant/frontend Ā· GitHub
but, also see this :
app-header
and app-toolbar
are still very much alive
If someone stumbles upon these for 2023.4.0 let me know:
card-mod-sidebar: |
:host {
background: var(--ha-card-background) !important;
div.menu {
background: transparent !important;
paper-icon-item[role=option], paper-icon-item[aria-role=option] {
.iron-selected paper-icon-item {
How do I change the color of the entire header?
Iāve tried a handful of variations on this:
app-header {
color: black !important;
mase
April 6, 2023, 10:32pm
1343
anyone knows how to move the back-arrow of a subview up?
.mdc-icon-button {
padding-bottom: 10px;
doesnĀ“t work for me
moving the title up worked with
.main-title {
danm89
April 6, 2023, 11:04pm
1344
Try this.
.header {
color: black;
Thanks, but I couldnāt get that to work.
I did find the HA built-in variable app-header-background-color:
that seems to do what I need except that I currently have that variable set to different colors for light and dark mode. For most of my devices, I want to keep the header background color intact for light and dark modes, but I need to turn it black based on a specific @media query selector on a specific device regardless of light/dark mode. I think the right way to do this is to place the media query in both light/dark mode sections, but cannot seem to figure out the right syntax for media queries in those sections.
modes:
light:
@media (orientation: landscape) and (min-width: 950px) {
.header {
--app-header-background-color: black;
So, hereās a new question:
Whatās the right way to wrap a built-in HA variable with a media query in the modes section of a theme?
Olivier1974
(Olivier Toussaint)
April 7, 2023, 8:30am
1346
Since 2023.4, my theme using card-mod is broken, but only in the companion app (iOS).
The culprit part is this:
card-mod-view-yaml: |
hui-masonry-view $: |
.badges {
margin-top: auto !important;
hui-masonry-view {
display: flex;
flex-direction: column-reverse;
justify-content: start;
It is to put the badges at the bottom of the pages.
It is working perfectly fine in a browser but in the companion app, the pages are opening at the bottom and it is not possible to scroll up.
At startup:
Trying to scroll (generating a refresh):
When I put the default theme (not using card-mod), everything is working as expected.
pepe59
(Pepe59)
April 7, 2023, 8:53am
1347
I have this code where the top bar has been moved down.
The color was black.
After the HA 2023.4 update the bar is back up and gray and I have no idea how to get it back down, black.
Everything else works fine.
Do you have any idea?
card-mod-theme: hapanel
# Header
ha-app-layout$: |
#contentContainer {
padding-top: 0px !important;
padding-bottom: 48px !important;
ha-tabs$: |
#tabsContainer {
display: flex;
justify-content: center;
ha-tabs {
height: var(--header-height);
--paper-tabs-selection-bar-color: #D2691E !important;
color: #696969 !important;
paper-tab[aria-selected=true] > ha-icon, paper-tab[aria-selected=true] {
color: #FF8C00 !important;
/* Let's change the background. */
background: black !important;
color: #A9A9A9 !important;
app-header {
top: calc(100vh - 48px) !important;
bottom: 0 !important;
transform: unset !important;
/* This adds the time */
ha-button-menu::before {
font-size: 18px;
height: 20px;
width: 100px;
margin-left: 150px;
margin-right: 150px;
content: "{{ states('sensor.aktualni_den') }}";
position: absolute;
top: 16px;
right: 48px;
mase
April 7, 2023, 9:09am
1348
try changing app-header
to .header
and app-toolbar
to .toolbar
, donĀ“t forget to reload your themes after changing it.
# Header
ha-app-layout$: |
#contentContainer {
ha-tabs$: |
#tabsContainer {
display: flex;
ha-tabs {
.header, .toolbar {
.header {
font-size: 18px;
height: 20px;
width: 100px;
margin-left: 150px;
position: absolute;
top: 16px;
right: 48px;
Mar1us
(Mar1us)
April 7, 2023, 9:14am
1349
since 2023.4 my very simple theme to remove the top header is not working anymore. Anyone how to fix?
Theme
#Mushrooms Shadow Theme for Mobile Interface
Mushroom Shadow Mobile:
card-mod-theme: Mushroom Shadow Mobile
card-mod-root: |
app-toolbar {
display: none;
# Home Assistant override
ha-card-box-shadow: 0px 2px 4px 0px rgba(0,0,0,0.16)
ha-card-border-width: 0
modes:
light:
primary-text-color: "#212121"
primary-background-color: "#EFEFEF"
# header
app-header-text-color: "var(--primary-text-color)"
app-header-background-color: "var(--primary-background-color)"
dark:
primary-text-color: "#DDDDDD"
primary-background-color: "#121212"
# header
mase
April 7, 2023, 9:15am
1350
try this:
card-mod-root: |
.toolbar {
display: none;
pepe59
(Pepe59)
April 7, 2023, 9:35am
1351
That worked, the top bar is down and all, but thereās one more problem.
After moving the bar down, it remains gray, empty at the top, taking up space on the tablet.
Thank you for your kind help.
Mar1us
(Mar1us)
April 7, 2023, 9:38am
1352
that didnĀ“t worked - still icons from the header are there
mase
April 7, 2023, 9:51am
1353
mase
April 7, 2023, 9:55am
1354
you need to edit some settings then. you might want to take a look at the theme that i use and start from thereā¦
Theme
Navbar_New:
card-mod-theme: "Navbar_New"
header-height: "60px"
"*:first-child$": |
#columns .column > * {
padding-left: 5px;
padding-right: 5px;
padding-bottom: 5px;
# Move navbar
ha-tabs$: |
#tabsContent {
width: 97%;
paper-icon-button {
display: none;
a.menu-link[target="_blank"], ha-button-menu, ha-menu-button, [main-title] {
div#view{
transform: initial;
padding: 0 !important;
position: fixed !important;
margin: 0 !important;
width: 100%;
height: 100% !important;
.header {
bottom: 0px !important;
box-shadow: var(--footer-shadow);
height: var(--header-height) !important;
.toolbar {
padding: 10px 0px !important;
background: var( --ha-card-background, var(--card-background-color) );
#view {
margin-top: calc(-1 * var(--header-height)) !important;
padding-bottom: var(--header-height) !important;
ha-tabs {
--paper-tabs-selection-bar-color: var(--header-tab-indicator-color) !important;
--mdc-icon-size: 26px;
display: flex;
justify-content: space-between;
padding: 10px;
margin-top: 15px;
color: var(--header-active-tab-color);
background-color: var(--header-active-tab-bg-color);
paper-tab {
color: rgb(var(--mush-rgb-disabled));
--paper-tab-ink: var(--card-background-color);
border-radius: 25px;
height: 30px;
padding: 0 20px;
.main-title {
.mdc-icon-button {
# Header / Footer
header-active-tab-color: "rgb(var(--paper-tab-selected))"
header-active-tab-bg-color: "var(--card-background-color)"
header-all-tabs-color: "rgb(var(--mush-rgb-disabled))"
header-tab-indicator-color: "var(--card-background-color)"
paper-tabs-selection-bar-color: "var(--card-background-color)"
footer-shadow: "var(--card-background-color)"
see 2 posts up your post.
use background:
instead of color:
pepe59
(Pepe59)
April 7, 2023, 10:02am
1356
Thanks, Iāll look into it.
S1M8N
(S1 M8 N)
April 7, 2023, 11:49am
1357
Hello everyone,
I search how can I use this code in my theme.yaml :
card-mod-more-info-yaml: &card-mod-more-info-yaml |
@supports (-webkit-backdrop-filter: none) or (backdrop-filter: none) {
.mdc-dialog__surface {
backdrop-filter: blur(16px);
-webkit-backdrop-filter: blur(16px);
background-color: rgba(var(--rgb-mdc-theme-surface), .5) !important;
box-shadow: 0 0px 16px 4px rgba(var(--dialog-box-shadow), .15), 0 16px 64px 32px rgba(var(--dialog-box-shadow), .5) !important;
Result :
with the browser_mod.popup
I donāt no if itās clear but if you have any question donāt hesitate
Thank you in advance for you help
Mar1us
(Mar1us)
April 7, 2023, 12:36pm
1358
Only if there is no other solution
