šŸ”¹ Card-mod - Super-charge your themes!
Any ideas on how to use :host to style the sidebar? I think it should be possible if I can stack it.
Hmmā€¦ my existing themeoveride.js with the border radius isnā€™t working now either and I hadnā€™t noticed because the themes seem to have that variable generally nowā€¦ was wondering why the corners were more roundedā€¦
Is there an alternate way to do this?
I added the wall of text at the bottom of the wiki for compact header to my theme. Looks pretty goodā€¦
However 2 issuesā€¦ with compact-header, I could use an image as the background for the header. Am I still able to do that?
Second, can I increase the space between the hamburger menu and the view tabs?
Second, adjust the padding-left here:
First, change
      .edit-mode, app-header, app-toolbar {
        background-color: var(--primary-background-color) !important;
        color: var(--primary-text-color) !important;
to
        background-color: transparent !important;
      app-header {
        background: url(myimg) !important;
Line 354 is as I am using from the wiki.
Tried:
      /*Uncomment this if you want the header on the bottom
      app-header {
        background-image: "center / cover no-repeat fixed url('/hacsfiles/themes/ios-themes/homekit-bg-blue-red.jpg')"
        top: calc(100vh - 48px) !important;
No difference to above screenshot.
also
      app-header {
        background: url('/hacsfiles/themes/ios-themes/homekit-bg-blue-red.jpg')
same result
Oh shit!! itā€™s commented out. duh!
You should probably remove the top part if you donā€™t want it at the bottom too. Let me know how it goes.
okā€¦ so using:
        background-image: "center / cover no-repeat fixed url('/hacsfiles/themes/ios-themes/homekit-bg-blue-red.jpg')" !important;
I see
So the views need to be shifted right some.
Changed to here:
      paper-tabs {
        --paper-tabs-selection-bar-color: var(--primary-color) !important;
        margin-left: 65px !important;
and this now:
Will that cause any issues I wonder?
Can I change the icon color so it stays white and only underlines the selected tab?
It shouldnā€™t cause any issues to do that.
The highlighting is built in to paper-tabs, the underlining was manually added. It already
I donā€™t see which setting to change to change the icon color or underline color.
Also not sure my image is working correctly. It looks different to how it did when I used Custom Headerā€¦
Iā€™m a CSS newb but Iā€™ve been trying to figure out how to put a border around a badge-card.
I tried the code below thinking it would be applied to the ā€œcurrent elementā€ which is the badge-card. However, I obviously have no clue what Iā€™m doing. Any help would be appreciated.
                style: |
                    border-top-width: 2;
                    border-top-width: solid;
                    border-right-width: 2;
                    border-right-width: solid;
                    border-left-width: 7px;
                    border-left-style: solid;
                    border-top-width: 7px;
                    border-top-style: solid;
                    border-right-width: 7px;
                    border-right-style: solid;
                    border-bottom-width: 7px;
                    border-bottom-style: solid;
Change the . to ha-card
hi, would you be so kind as to share the settings of the second view?
I used the settings at the bottom of the wiki and set margin-left to 65px as shown. You can check here for my full themeā€¦
Itā€™s the ios-dark-mode-blue-red oneā€¦
First of all, sorry for touching the eggs so much ā€¦
I canā€™t remove the chevrons and the three dots when I try the side menu button disappears, letā€™s see if someone can help me, this is how I have it now:
  card-mod-theme: personal
  card-mod-root-yaml: |
    paper-tabs:
        .not-visible {
          display: none;
        #selectionBar {
          bottom: unset !important;
    "ha-app-layout":
        #contentContainer {
          padding-top: 48px !important; /*Change this to 0px if you want the header on the bottom*/
      app-toolbar {
        height: 0;
        background: url('/local/fondo_negro.png') !important;
      app-header {
      app-header.edit-mode {
        border-bottom: 2px var(--primary-color) solid;
        padding-bottom: 10px;
      app-header[shadow] > ::before {
        box-shadow: inset 0px 5px 6px -3px rgba(0, 0, 0, 0.3);
      #add-view ha-svg-icon {
        background-color: var(--primary-color) !important;
        color: #EEE !important;
        border-radius: 5px !important;
      .edit-icon {
      mwc-icon-button[label="Start conversation"] {
        top: 0;
        right: calc(48px * 1);
        z-index: 2;
        position: absolute;
      mwc-icon-button[title="Help"] {
        top: 0;
        right: calc(48px * 2);
        position: absolute;
        z-index: 2;
      mwc-icon-button[title="Close"] {
        top: 0;
        left: 0;
        position: absolute;
        z-index: 2;
      mwc-icon-button#add-view {
        position: fixed;
      ha-button-menu {
        top: 0;
        right: 0;
        z-index: 2;
        margin-left: 5px;
        position: absolute;
        /*Uncomment this out to hide the overflow menu
        display: none;
      app-toolbar > [main-title] {
        display: none;
      menu-button[style="visibility: hidden;"] {
        display: none;
      ha-menu-button {
        z-index: 2;
        top: 24px;
      paper-tabs {
        --paper-tabs-selection-bar-color: transparent !important;
      paper-tab[aria-selected="true"] > ha-icon {
        color: orange !important;
      paper-tab[aria-selected="true"] {
      @media (orientation: portrait) {
        paper-tabs {
          margin-left: 64px !important;
          margin-right: 32px !important;
        ch-header > paper-tabs,
        app-header.edit-mode > * > paper-tabs {
          margin-left: 10px !important;
          margin-right: 10px !important;
      ch-header > ha-button-menu {
        top: unset;
      app-header.edit-mode > paper-tabs {
        margin-left: 0;
      app-toolbar a {
Hello everyone
How can I fix this situation ?
Screenshot_107
Thanks for the reply. The badge-card does not have an ā€œha-cardā€ element (I guess element is the correct terminology to use, or should I say it is not derived from the ā€œha-cardā€ style?) So, when replacing the ā€œ.ā€ with ā€œha-cardā€, it still doesnā€™t work.
When I inspect the badge-card I see:
  • element
  • .cards
  • element (inherited from hui-view)
  • :host (inherited from hui-root)
  • :host (inherited from home-assistant-main)
  • element (inherited from home-assistant)
  • ā€¦
What I was trying to do, and given my limited understanding of CSS I donā€™t if this is possible, is to end up with whatā€™s shown below. I thought the ā€œ.ā€ selector applied the style to the current element, which in the case would be the badge-card.
<badge-card style="border-left-width: 7px;border-left-style: solid;border-top-width: 7px;border-top-style: solid;border-right-width: 7px;border-right-style: solid;border-bottom-width: 7px;border-bottom-style: solid;">
Thanks again for your help.
Are you trying to style badges? Most cards are moddable with ha-card.
You can increase the margin-right. So I can help you, are you on mobile?
I need an odd number of votes so that the overflow button isnā€™t 50%. If you havenā€™t voted yet, please vote.
Thank you, everything worked out.
Added here:
paper-tabs {
        margin-left: 48px !important;
        margin-right: 30px !important;
Put together a quick compact-header config for this in case anyone is interested. Itā€™s just the standard compact header look, wonā€™t affect edit mode (aside from shifting cards, will look for a fix), and should keep backgrounds and cards in the view unaffected. Commented as much as possible for any adjustments that would be needed.
compact-header:
  card-mod-theme: compact-header
    ha-app-layout$: |
        /* This corrects top padding for the view. */
        #contentContainer {
    paper-tabs$: |
        /* This hides tab scroll arrows, remove next 3 lines if you want them. */
        paper-icon-button {
          display: none;
        /* This makes it so arrows are only displayed when needed. */
        .not-visible {
          display: none;
      /* This shifts the unused portion of the header up. */
      app-toolbar:not([class="edit-mode"]) {
        margin-top: -64px;
        z-index: 1;
      /* This shifts the menu button back down. */
      app-toolbar:not([class="edit-mode"]) ha-button-menu {
        margin-top: 110px
      /* This shifts the voice button back down. */
      app-toolbar:not([class="edit-mode"]) mwc-icon-button[label] {
        /* Uncomment line below to hide voice button. */
        /* display: none; */
        margin-top: 110px
      /* This shifts the options button back down. */
      app-toolbar:not([class="edit-mode"]) ha-menu-button {
        /* Uncomment line below to hide options button. */
        margin-top: 110px
      /* This hides the menu button when sidebar is open. */
        display: none;
      /* This adds room for the menu button when sidebar is open. */
      :host-context(home-assistant-main[expanded]) paper-tabs {
        margin-left: 60px !important;
      /* This leaves space for the buttons on the right of the tabs bar.
         Change 112px to 56px if you don't use voice icon. */
      paper-tabs {
          margin-right: 112px !important;
      /* This corrects the sizing of the view. */
      #view {
        min-height: calc(100vh - 48px) !important;
You sir are AWESOME !!
