Can card-modder be used to apply styles based on entity state? If so, what is the proper syntax for doing so? I’d like to tweak the color and opacity of text within a card based on whether or not the entity is on/off.
See the second example under ‘Extra Styles’
Thanks for the suggestion. I’m not sure that template is quite applicable in my use case.
