KrisBird
(Kris Bird)
December 28, 2018, 8:37am
1
I get an error when trying to use the lovelace card-modder - using the example by thomasloven.
I have placed the card-tools.js in the www folder (just by copy paste) and tried to place card-modder.js (copy paste) in www folder, www/custom_ui folder - same result everytime.
I get this error in lovelace: “Can’t find card-tools. See https://github.com/thomasloven/lovelace-card-tools ”
This is my lovelace.yaml file (other cards are omitted from the below code)
resources:
url: /local/card-tools.js #?v=0
type: js
url: /local/custom_ui/card-modder.js
type: module
title: Test
icon: mdi:music
cards:
type: custom:card-modder
style:
– paper-card-background-color: rgba(0, 100, 0, 0.2)
– paper-item-icon-color: white
border-radius: 5px
color: rgb(0, 0, 100)
card:
type: glance
title: Styled card
entities:
- light.carport
- light.hallway
- light.kommode
type: glance
title: Unstyled card
entities:
- light.carport
- light.hallway
- light.kommode
Looks like the path to your card-tools is different to the one used for card-modder are they in the same location?
KrisBird
(Kris Bird)
December 28, 2018, 10:04am
3
I have tried to have them in the same folder - with no luck.
It’s hard to tell with out it being formatted correctly but there seems to be a hash tag before the version tag. Let me get my config to show you
resources:
- url: /local/custom_ui/dark-sky-weather-card.js?v=4
type: js
- url: /local/custom_ui/mini-media-player-bundle.js?v=0.9.8
type: module
- url: /local/custom_ui/tracker-card.js?v=0.1.5
type: js
- url: /local/custom_ui/surveillance-card.js?v=0.0.1
type: module
- url: /local/custom_ui/mini-graph-card/mini-graph-card-bundle.js?v=0.1.0
type: module
- url: /local/custom_ui/card-modder.js?v=35eb37
type: module
- url: /local/custom_ui/slider-entity-row.js?v=d6da75
type: js
- url: /local/custom_ui/card-tools.js?v=445b68
type: js
- url: /local/custom_ui/layout-card.js?v=bd7e5a
type: js
KrisBird
(Kris Bird)
December 28, 2018, 10:16am
5
I have both tried to include the text behind the # like this:
url: /local/card-tools.js?v=0
type: js
and leaving it out like this
type: js
I have tried with the car-modder both in the /local folder and in the /local/custom_ui folder.
Any other ideas are greatly appreciated and thank you for taking your time
can you double check the card-tools.js file matches the one from his github I had this error with the custom-tracker card where i didn’t copy correctly. Make sure you click on the raw and copy from there.
KrisBird
(Kris Bird)
December 28, 2018, 10:23am
7
I will try that. In my search for solutions I just came across this comment from thomasloven:
‘I forgot to mention in the docs that card-tools and any card that uses it required Home Assistant version 0.84.0 or later.’
As I was running 0.83 I will try to update HA first
KrisBird
(Kris Bird)
December 28, 2018, 11:52am
8
Didn’t help with the upgrade to 0.84.6 - but then again now I use the rawconfig editor to edit lovelace an not the ui_lovelace.yaml file. Not sure what to think about that….
KrisBird
(Kris Bird)
December 28, 2018, 1:16pm
9
Figured it out at last. CSS does not work on Edge or Safari - so now I am using Chrome
