Oh, I see that you have already solved it and replied about it before and I just posted the same solution that you mentioned.
I should have read more carefully. But I have provided a detailed solution with links so wonât delete it - maybe it will help anyone.
But I think I have a solution for ceiling cassette AC which has a separate Carrier app so want to share this too since you mentioned that you havenât solved your cassette AC integration yet.
It is not a perfect integration but what I really need is to turn it on in the morning and turn it off in the evening.
So I have attached an action in Home Assistant to sunrise to turn it on and 10pm to turn it off.
I have modified my /config/configuration.yaml with File Editor and added this to it
shell_command:
cassete_off: 'curl -X GET "x.x.x.x/aircon/set_control_info?stemp=22&pow=0"'
cassete_on: 'curl -X GET "x.x.x.x/aircon/set_control_info?stemp=22&pow=1"'
And then with a button or an automation you call âserviceâ shell_command.cassete_off or shell_command.cassete_on
Like that you can change the temperature or fan mode or other parameters too. if you like I can help you more with the parameters.
And wow, we are in exact same boat :I have the exact same amount and types of Carrier AC as you and also living in Thailand.
Actually I havenât installed the second wall AC for 9 months and was waiting for Carrier to help me with integration or throw out this AC and install Daikin.
Because in 2023 all ACs should have Smart Home capability, not just a laggy unresponsive app, done by a junior mobile developer. wtf.
But decided to finally install it now and few days later googled the solution by accident and got it working.
(and at the same time updated my Daikin Zetas firmware so cannot use it with Home Assistant anymore so probably will replace it with Carrier X-Inverter model now that it works with HA). So this is actually a â2 steps forward 1 step backâ kind of situation for me but itâs ok.
I have Zigbee 3-button remotes Tuya Smartlife ZigBee Remote āļĢāļĩāđāļĄāļāļāļāļāđāļāļĢāļĨ āđāļāļ 3 āļāļļāđāļĄ āļĢāļĩāđāļĄāļāļāļđāļĒāđāļē āļŠāļąāđāļāļāļēāļāđāļāđ 9 āđāļāļ āļāļ§āļāļāļļāļĄāļāđāļēāļāđāļāļāļāļĨāļīāđāļāļāļąāđāļ Tuya smartlife Zigbee Wall Remote Switch āļŠāļ§āļīāļāļāđāļĢāļĩāđāļĄāļāđāļĢāđāļŠāļēāļĒ āļŠāļ§āļīāļāļāđ 3 āļāļļāđāļĄ āļĢāļĩāđāļĄāļāļāļāļāđāļāļĢāļĨāđāļĢāđāļŠāļēāļĒ āļŠāļ§āļīāļāļāđāļāļāļąāļ āļĢāļĩāđāļĄāļāļāļāļāļēāđāļāđ āļĢāļĩāđāļĄāļāđāļĢāđāļŠāļēāļĒ āļĢāļĩāđāļĄāļāļāļđāļĒāđāļē āļŠāļąāđāļāļāļēāļāđāļāđ 9 āđāļāļ
So much amazing stuff can be done with them. Most of Zigbee stuff is Tuya cloud but works fine with local Zigbee device plugged into Home Assistant.
For example I have one remote like this in my bedroom.
One click of the middle button turns on AC for 5 minutes . Double tap on a middle button turns it into high power mode. Multiple clicks/double clicks adds 5 more minutes.Long press stops all timers and turns AC off.
Click on button 1 or 3 (because you donât need to know which is which when you just woke up and can use any of these buttons) toggles soft lighting, double click on them toggles full light.
The possibilities of home automation are endless with Home Assistant, Zigbee devices and other smart devices. I think that you should not spend time opening device apps or using device remotes when you can automate things better and not think when it is not required.
Have a good day!
