I’m trying to cast a dashboard to a tv with a chromecast each morning that contains weather, commute, calendar info… It all looks fine in home assistant but I can’t seem to get the calendar to cast. I’m using a 30 day calendar view for special events/birthdays and a one day view for my daily agenda. When I cast the old custom calendar card I see the titles but no events. If I try the Atomic Calendar, I get the “custom element doesn’t exist” error. Does anyone have something like this working?
I’m trying to do exactly the same thing and having the same issue.
The HA Cast FAQs says:
Some custom cards rely on things that are only available in the normal Home Assistant interface. This requires an update by the custom card developer.
If you’re a custom card developer: the most common mistake is that LitElement is extracted from an element that is not available on the page.
Can anyone share insights into whether the Calendar Card is fundamentally unsuited to being casted or if there is something I could do to help get it working?
Thanks!
