Cast reolink camera to tablet upon motion
I am currently running home assistant with fully kiosk on several tablets. I am trying to figure out a way that if one of the reolink security cameras around my house pick up motion that it will pop up a stream on the tablets four thirty seconds or so and then resume back to normal.
Can you cast camera stream to your tablet ?
No it says unsupported media type when I try to use “play camera stream”
So i looks like to me that first of all you will have to solve problem with stream casting. As I don’t have tablet I don’t know does they or some models support casting to it. You should check your tablet spec and see if there is a way for casting on the tablet.
If you have tv with cromecast you can try that first. Maybe your ha or other settings doesn’t allow you to cast.
Setting this if you have casting supported device is easy. Just create automation that will trigger when motion is detected and cast live camera stream on device.
Yes i have gotten this to work with chromecast. It appears to be an issue with fully kiosk not allowing hls stream to go through. Just hoping someone has a workaround
