Cast to Google Hub any Home Assistant Cameras - WIP
Using Home Assistant camera proxy it’s possible stream any cameras to Google Hub.
The camera used in this video are:
  • Old Foscam FI9828W
Foscam FI9828P - Mozilla Firefox
  • Old Foscam FI9816P
foscam vecchia
  • New Ezivz CTQ2C
    ezviz
In Home Assistant I wrote few script with a MQTT publish command, and this Scripts with Nabu Casa are scenes.
When call a Scene, start the Node-red flow for retrieve the access token of the requested camera, grab image, save it on a file and cast to Google Home. This process loop for 8 times, then close the Cast.
Here a cycle
It’s a working process …
Bye
Sandro
Very cool! I like it! smart idea use image! Great idea! Do you have some code to share github or documentation, more info?
hello @Sdomotica_Automation,
can you provide some code snippet?
I have some problem on keep control of google hub from home assistant which function are you using to start the playback?
I use nodered cast
Bye
Sandro
Hi Sandro!
A couple of interesting things in your approach!!
Could you share code/node-red flow?
Particularly interested on how did you get the url/token for the cameras and what H=Google HUB node did you use.
Thanks!
Hi Sandro,
I have the same case : old foscam’s with a Nest Hub to stream to.
It works, but could you share the code of the definition of your proxy camera ?
Thanks !
