I have HA with 2 network:
192.168.1.0/24 for LAN
192.168.7.0/24 for IoT VLAN
Also in VLAN network I have a few Nest Hub and when I use cast.show_lovelace_view, Nest Hub try to connect to 192.168.1.0/24 HA ip address instead of IoT VLAN (192.168.7.0/24).
Is there any way to configure the IP for cast when using show_lovelace_view? Thanks!
Hi ,
Segmented networks are not officially supported within HA.
HA is designed and expects a flat subnet to work as intended. This includes HA casting to things .
This is because every segmented network is different for IP’s and number of segments and firewalls and sharing rules and about 650495849085 other things.
This does not mean you can’t use them or that they can’t be made to work, it means that to get them working you are the support structure on your own subnet(s).
It’s OK to ask, but there is not a lot of people that can help.
