I’ve got a few cameras that I’m trying to have show up on my Nest Hub Max through Google Assistant. I’m getting odd behavior with the cameras where some show up rotated 90 degrees on the display. All of these cameras work absolutely great inside of the HA UI and stream component is enabled. Per this thread & @iantrich, this should be working
Here’s the rundown and the excerpt config for it all below:
- Front Door - Shows up and displays with 90 degree clockwise rotation.
- Garage Camera - Shows up and displays with 90 degree clockwise rotation.
- Street Camera - Shows up and when I select to view it, it tries to display but is not able to connect and show the feed. This is the same exact camera hardware as the front door camera.
- Garage Door Camera - Does not show up at all in camera’s list on next hub (might be unsupported as it’s a really old Foscam)
- Printer Camera - Shows up and displays correctly without any rotation
google_assistant:
entity_config:
camera.front_door:
name: "Front Door Camera"
expose: true
camera.garage_dome:
expose: true
room: "Garage"
camera.garage_door_outside:
expose: true
room: "Garage"
camera.garage_door:
name: "Garage Door Camera"
expose: true
room: "Garage"
camera.printer:
expose: true
room: "Workshop"
camera:
- platform: generic
framerate: 4
still_image_url: 10.30.30.21
username: !secret camera_username
password: !secret camera_password
verify_ssl: false
- platform: ffmpeg
input: 10.30.30.24
extra_arguments: -pred 1 -q:v 2
amcrest:
- host: 10.30.30.20
- host: 10.30.30.22
name: Garage Door Outside
- host: 10.30.30.25
