Cat: can't open '/run/supervisor': No such file or directory
I’m trying to install HA version 6.6 on an old Raspberry pi 1 Model B board, The installation process seems to go well , and the observer is showing Connected,Supported,Healthy for a minute, until the supervisor image get updated to 2022.11.2, after that the observer shows “Disconnected” and the log shows that the supervisor is looping trying to start with error message “cat: can’t open ‘/run/supervisor’: No such file or directory”, I’ve tried different SD cards with the same result, here is the log I get from the landing page :
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/udev.sh
[04:51:40] INFO: Using udev information from host
cont-init: info: /etc/cont-init.d/udev.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun supervisor (no readiness notification)
services-up: info: copying legacy longrun watchdog (no readiness notification)
s6-rc: info: service legacy-services successfully started
[04:51:41] INFO: Starting local supervisor watchdog...
[04:51:48] INFO: Supervisor restart after closing
[04:51:56] INFO: Supervisor restart after closing
[04:52:04] INFO: Supervisor restart after closing
[04:52:11] INFO: Supervisor restart after closing
[04:52:18] INFO: Supervisor restart after closing
[04:52:26] INFO: Supervisor restart after closing
[04:52:34] INFO: Supervisor restart after closing
[04:52:41] INFO: Supervisor restart after closing
[04:52:49] INFO: Supervisor restart after closing
[04:52:57] INFO: Supervisor restart after closing
[04:53:04] INFO: Supervisor restart after closing
[04:53:12] INFO: Supervisor restart after closing
[04:53:19] INFO: Supervisor restart after closing
[04:53:28] INFO: Supervisor restart after closing
[04:53:36] INFO: Supervisor restart after closing
[04:53:44] INFO: Supervisor restart after closing
[04:53:51] INFO: Supervisor restart after closing
[04:53:59] INFO: Supervisor restart after closing
[04:54:06] INFO: Supervisor restart after closing
[04:54:15] INFO: Supervisor restart after closing
[04:54:22] INFO: Supervisor restart after closing
[04:54:30] INFO: Supervisor restart after closing
[04:54:38] INFO: Supervisor restart after closing
[04:54:46] INFO: Supervisor restart after closing
[04:54:53] INFO: Supervisor restart after closing
[04:55:01] INFO: Supervisor restart after closing
[04:55:09] INFO: Supervisor restart after closing
[04:55:19] INFO: Supervisor restart after closing
[04:55:29] INFO: Supervisor restart after closing
[04:55:39] INFO: Supervisor restart after closing
[04:55:49] INFO: Supervisor restart after closing
[04:55:58] INFO: Supervisor restart after closing
[04:56:07] INFO: Supervisor restart after closing
[04:56:16] INFO: Supervisor restart after closing
[04:56:26] INFO: Supervisor restart after closing
[04:56:35] INFO: Supervisor restart after closing
cat: can't open '/run/supervisor': No such file or directory
[04:56:43] WARNING: Halt Supervisor (Wuff)
[04:56:43] INFO: Watchdog restart after closing
s6-rc: info: service legacy-services: stopping
[04:56:45] INFO: Watchdog restart after closing
s6-svwait: fatal: supervisor died
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
[04:56:47] INFO: Supervisor restart after closing
the installed docker ps containers are :
homeassistant/armht-hassio-supervisor:latest     "/init"
ghcr.io/home-assistant/raspberrypi-homeassistant:landingpage     "/init"
ghcr.io/home-assistant/armhf-hassio-dns:2022.04.1     "/init"
ghcr.io/home-assistant/armhf-hassio-cli:2022.11.0     "/init /bin/bash -c "
ghcr.io/home-assistant/armhf-hassio-observer:2021.10.0     "/init"
