I want to share my cat feeder and water fountain.
Before, I had a pretty similar set up but I had to move to ESP because ZigBee wasn´t so reliable and several times the feeder didn’t work, but now that is all in the past.
So, the setup is an ESP8266 to control a 24VDC (can be 12VDC) motor and a 5VDC water pump (almost all the water cat fountain are 5VDC) and a PIR motion sensor to start the pump when is need it.
The part list is the following:
220VAC to 24VDC converter
220VAC to 5VDC converter
Two Push buttons
ESP8266 NodeMCU
2 Ralay Module
Generic PIR sensor
24 VDC (about 15 rpm)
5VDC water fountain
Cereal Dispenser
CNC Motor Jaw Shaft Coupler 5mm To 8mm Flexible Coupling (size depend on the shaft of the motor and the cereal dispenser)
Some DuPont cables
Some extra cables
Some patience…
Most of the code is on ESPHome, so is no need to be connected all the time to HA. I’m planning to add a clock module to the ESP8266 so in case of blackout it still has the time…
The ESPHome program has the following controls on HA use:
- First meal Time
- Second meal Time.
- Time duration of the feed motor (let say 15 sec each meal)
- Water time after motion is clear (let say 10 sec.)
- Feed Button
- Water Buton
Hope you enjoy it!!
ps. Some parts of the code is in spanish… just google the words so it make sense…
The code:
esphome:
friendly_name: cat feeder
esp8266:
board: nodemcuv2
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "Vnvo3Jd6ufsdffsfdshgtfhtrhrth7AN8O8="
ota:
password: "5d1hdfhfgghfg7813c436a73a158"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Cat-Feeder Fallback Hotspot"
captive_portal:
switch:
- platform: gpio
pin: D1
inverted: true
restore_mode: ALWAYS_OFF
name: "HA switch agua"
optimistic: true
on_turn_on:
- logger.log: "############################# Power ON #############################"
- switch.turn_on: relay_agua
on_turn_off:
- logger.log: "############################# Power OFF #############################"
- switch.turn_off: relay_agua
optimistic: true
on_turn_on:
- switch.toggle: ha_switch_agua
- delay: 240 sec
- if:
condition:
# Same syntax for is_off
binary_sensor.is_off: pir_sensor
then:
- switch.turn_off: ha_switch_agua
- switch.turn_off: water_on_delay
- platform: gpio
pin: D7
inverted: true
# The following can be omitted
- platform: restart
name: "HA Feed Button"
optimistic: true
on_turn_on:
- switch.turn_on: water_on_delay
on_turn_off:
- text_sensor.template.publish:
state: !lambda |-
char str[17];
time_t currTime = id(homeassistant_time).now().timestamp;
strftime(str, sizeof(str), "%m-%d-%Y %H:%M", localtime(&currTime));
return { str };
# strftime(str, sizeof(str), "%Y-%m-%d %H:%M:%S", localtime(&currTime));
number:
name: "Timepo agua despues de sin movimiento"
optimistic: true
min_value: 0
max_value: 60
step: 5
mode: box
initial_value: 10
restore_value: true
optimistic: true
min_value: 1
max_value: 25
step: 1
mode: box
initial_value: 12
restore_value: true
optimistic: true
initial_value: 7
min_value: 0
max_value: 24
step: 1
mode: box
optimistic: true
initial_value: 19
min_value: 0
max_value: 24
step: 1
mode: box
optimistic: true
initial_value: 30
min_value: 0
max_value: 60
step: 1
mode: box
optimistic: true
initial_value: 30
min_value: 0
max_value: 60
step: 1
mode: box
binary_sensor:
##################################### agua############################
- platform: gpio
pin: D0
device_class: motion
on_press:
- if:
condition:
and:
- lambda: 'return id(homeassistant_time).now().hour >= 7;'
- lambda: 'return id(homeassistant_time).now().hour <= 23;'
then:
- switch.turn_on: ha_switch_agua
on_release:
then:
- delay: !lambda "return ((id(water_time_after_clear).state * 1000));"
- if:
condition:
then:
- platform: gpio
pin:
number: D2
inverted: true
filters:
- delayed_on: 50ms
- delayed_off: 50ms
on_press:
then:
- logger.log: "############################# Power on/off PRESS #############################"
- delay: 240 sec
- if:
condition:
then:
########################### fin agua############## inicio comida ########################
- platform: gpio
pin:
number: D3
inverted: true
filters:
- delayed_on: 400ms
- delayed_off: 50ms
on_press:
then:
- delay: 0.0 sec
- switch.turn_on: ha_feed_button
on_release:
then:
- switch.turn_off: ha_feed_button
interval:
- interval: 60sec
then:
- lambda: |-
float h1 = id(hora_1).state;
float m1 = id(minuto_1).state;
float hah = id(homeassistant_time).now().hour;
float ham = id(homeassistant_time).now().minute;
ESP_LOGD("main", "hora_1: %0.0f; minuto_1: %0.0f xxxxxxx HA_hora: %0.0f; HA_minuto: %0.0f; ",h1,m1,hah,ham);
- if:
condition:
or:
- and:
- lambda: 'return id(hora_1).state == id(homeassistant_time).now().hour ;'
- lambda: 'return id(minuto_1).state == id(homeassistant_time).now().minute;'
- and:
- lambda: 'return id(hora_2).state == id(homeassistant_time).now().hour;'
- lambda: 'return id(minuto_2).state == id(homeassistant_time).now().minute;'
then:
- lambda: ESP_LOGD("main", "ZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZ");
- lambda: ESP_LOGD("main", "Inicio");
- delay: !lambda "return ((id(duration).state * 1000));"
- lambda: ESP_LOGD("main", "Fin");
time:
- platform: homeassistant
# Text sensors with general information.
text_sensor:
# Expose ESPHome version as sensor.
- platform: version
# Expose WiFi information as sensors.
- platform: wifi_info
ip_address:
bssid:
# human readable update text sensor from sensor:uptime
name: Uptime Human Readable
icon: mdi:clock-start
name: "Hora Encendido"
- platform: wifi_signal
update_interval: 60s
- platform: copy # Reports the WiFi signal strength in %
source_id: wifi_signal_db
name: "WiFi Signal Percent"
filters:
- lambda: return min(max(2 * (x + 100.0), 0.0), 100.0);
unit_of_measurement: "Signal %"
entity_category: "diagnostic"
# human readable uptime sensor output to the text sensor above
- platform: uptime
name: Uptime in Days
on_raw_value:
then:
state: !lambda |-
int seconds = round(id(uptime_sensor_days).raw_state);
int days = seconds / (24 * 3600);
seconds = seconds % (24 * 3600);
int hours = seconds / 3600;
seconds = seconds % 3600;
int minutes = seconds / 60;
seconds = seconds % 60;
return (
(days ? String(days) + "d " : "") +
(hours ? String(hours) + "h " : "") +
(minutes ? String(minutes) + "m " : "") +
(String(seconds) + "s")
).c_str();
Some Pictures:
![IMG_0882](https://community-assets.home-assistant.io/original/4X/a/6/3/a631bd380ba734bd6a0bf1fd6893cc923f56578d.jpeg)
![IMG_0884](https://community-assets.home-assistant.io/original/4X/2/9/c/29c225aed59e050f6ed8b98586db3292d0b34695.jpeg)
![IMG_0885](https://community-assets.home-assistant.io/original/4X/9/6/8/9681d8fd7b7164a5fca49add3ebec5c24cda0729.jpeg)
