hey,
I’ve been playing around with HA since a couple of month and I did quite some progress using the documentation and the community.
I use a couple of value template in my configuration.yaml and in this case especially with the Xiaomi Air Purifier.
I use the following config
sensors:
mi_air_purifier_temp:
friendly_name: "Temperature"
value_template: "{{ state_attr('fan.mi_air_purifier_3h', 'temperature') }}"
unit_of_measurement: "°C"
device_class: "temperature"
mi_air_purifier_humidity:
friendly_name: "Humidity"
value_template: "{{ state_attr('fan.mi_air_purifier_3h', 'humidity') }}"
unit_of_measurement: "%"
device_class: "humidity"
mi_air_purifier_air_quality_pm25:
friendly_name: "Air quality (AQI) PM2.5"
value_template: "{{ state_attr('fan.mi_air_purifier_3h', 'aqi') }}"
unit_of_measurement: "μg/m³"
icon_template: "mdi:weather-fog"
mi_air_purifier_avg_air_quality_pm25:
friendly_name: "Average air quality (AvgAQI) PM2.5"
value_template: "{{ state_attr('fan.mi_air_purifier_3h', 'average_aqi') }}"
icon_template: "mdi:weather-hazy"
mi_air_purifier_use_time:
friendly_name: "Time used"
value_template: >
{% macro phrase(value, name) %}
{%- set value = value | int %}
{%- set end = 's' if value > 1 else '' %}
{{- '{} {}{}'.format(value, name, end) if value | int > 0 else '' }}
{%- endmacro %}
{% set weeks = (state_attr('fan.mi_air_purifier_3h', 'use_time') | int / 604800) | int %}
{% set days = ((state_attr('fan.mi_air_purifier_3h', 'use_time') | int - (weeks * 604800)) / 86400) | int %}
{% set hours = ((state_attr('fan.mi_air_purifier_3h', 'use_time') | int - (weeks * 604800) - (days * 86400)) / 3600) | int %}
{% set minutes = ((state_attr('fan.mi_air_purifier_3h', 'use_time') | int - (weeks * 604800) - (days * 86400) - (hours * 3600)) / 60) | int %}
{% set seconds = (state_attr('fan.mi_air_purifier_3h', 'use_time') | int - (weeks * 604800) - (days * 86400) - (hours * 3600) - (minutes*60)) | int %}
{{ [ phrase(weeks, 'week'), phrase(days, 'day'), phrase(hours, 'hr'), phrase(minutes, 'min'), phrase(seconds, 'sec') ] | select('!=','') | list | join(', ') }}
icon_template: "mdi:heart-pulse"
mi_air_purifier_filter_used:
friendly_name: "Filter used"
value_template: "{{ state_attr('fan.mi_air_purifier_3h', 'filter_hours_used') }}"
unit_of_measurement: "hrs"
icon_template: "mdi:heart-off"
mi_air_purifier_filter_remaining:
friendly_name: "Filter remaining"
value_template: "{{ state_attr('fan.mi_air_purifier_3h', 'filter_life_remaining') }}"
icon_template: "mdi:heart-outline"
mi_air_purifier_purify_volume:
friendly_name: "Purified volume"
value_template: "{{ state_attr('fan.mi_air_purifier_3h', 'purify_volume') }}"
unit_of_measurement: "m³"
icon_template: "mdi:warehouse"
mi_air_purifier_speed:
friendly_name: "Motor speed"
value_template: "{{ state_attr('fan.mi_air_purifier_3h', 'motor_speed') }}"
unit_of_measurement: "rpm"
icon_template: "mdi:speedometer"
mi_air_purifier_led_brightness:
friendly_name: "Led brightness"
value_template: "{{ state_attr('fan.mi_air_purifier_3h', 'led_brightness') }}"
unit_of_measurement: "lx"
icon_template: "mdi:brightness-5"
This does work if the Xiaomi Air Purifier is powered on.
If it isn’t, i get some warnings in my log file.
e.g.:
- Invalid option: None (possible options: Auto, Silent, Favorite, Fan)
- Air Purifier fan level update: Error executing script. Invalid data for call_service at pos 1: Invalid value for input_number.mi_air_purifier_fan_level: 0.0 (range 1.0 - 3.0)
- Value cannot be processed as a number: <state sensor.mi_air_purifier_air_quality_pm25=None; unit_of_measurement=μg/m³, friendly_name=Air quality (AQI) PM2.5, icon=mdi:weather-fog @ 2020-06-26T19:04:04.927873+02:00> (Offending entity: None)
I understand that if the device is offline it doesn’t return a valid value or number. But is it somehow possible to set a specific value in case the device is offline and doesn’t return a valid value?
Alternatively, is it possible to prevent that these warnings are being written to the log?
thx and Best,
pete
