How do I listen to enter/leave zone events fired by a device tracker? I’ve zones set up, it works fine as a part of an automation rule:
- id: '1569482179999'
alias: Check zones
- entity_id: device_tracker.life360
event: enter
platform: zone
zone: zone.work
condition: []
- data:
message: Entered work
title: Zone changed
service: notify.myself
I was trying to accomplish the same thing using AppDaemon with no luck. If I run the code shown below (assuming every event should be captured), it catches some events from a Xiaomi button and HA internals like call service, but none related to zones:
I don’t use the zone integration myself, so probably can’t help you much.
Does the device tracker “device_tracker.life360” have an attribute, which shows in which zone the device_tracker is in?
Or does the state of the device tracker change to the name of the zone when you enter a different zone?
So for example if you leave home and enter work, does the status of the device tracker change from “home” to “work”?
I’ve read some posts of people with a similar setup and as far as I understand, if the device tracker changes zones, the device tracker will show the name of the zone as the status of the device tracker.
If this is correct, you can use “listen_state” on the device tracker, something like this:
def initialize(self):
self.listen_state("device_tracker.life360", self.zone_changed)
def zone_changed(self, entity, attribute, old, new, kwargs):
if old != new:
# notify that zone changed for device tracker life360, old=previous zone, new=current zone
The new state is “work” so yes, your approach will work, thank you for the comprehensive answer!
But I’m still wondering why listen_event approach does not work.
