The Hassio log shows:
2020-06-07 08:29:01 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for garbage_collection which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
2020-06-07 08:29:01 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
2020-06-07 08:29:01 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for badnest which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
2020-06-07 08:29:03 WARNING (Recorder) [homeassistant.components.recorder] Ended unfinished session (id=110 from 2020-06-07 04:26:47.197642)
2020-06-07 08:29:17 WARNING (MainThread) [homeassistant.setup] Setup of badnest is taking over 10 seconds.
2020-06-07 08:29:18 ERROR (MainThread) [zigpy.application] Couldn't start application
2020-06-07 08:29:18 ERROR (MainThread) [homeassistant.components.zha.core.gateway] Couldn't start TI_CC: CC2531, CC2530, CC2652R, CC1352 etc, Texas Instruments ZNP protocol coordinator
File "/usr/src/homeassistant/homeassistant/components/zha/core/gateway.py", line 141, in async_initialize
app_config, auto_form=True, start_radio=True
File "/usr/local/lib/python3.7/site-packages/zigpy/application.py", line 65, in new
await app.startup(auto_form)
File "/usr/local/lib/python3.7/site-packages/zigpy_cc/zigbee/application.py", line 92, in startup
self.version = await self._api.version()
File "/usr/local/lib/python3.7/site-packages/zigpy_cc/api.py", line 241, in version
version = await self._command(Subsystem.SYS, "version", {})
File "/usr/local/lib/python3.7/site-packages/zigpy_cc/api.py", line 103, in _command
return await self.request(subsystem, command, payload)
File "/usr/local/lib/python3.7/site-packages/zigpy_cc/api.py", line 107, in request
return await self.request_raw(obj, expected_status)
File "/usr/local/lib/python3.7/site-packages/zigpy_cc/api.py", line 129, in request_raw
result = await waiter.wait()
File "/usr/local/lib/python3.7/site-packages/zigpy_cc/api.py", line 39, in wait
return await asyncio.wait_for(self.future, self.timeout / 1000)
File "/usr/local/lib/python3.7/asyncio/tasks.py", line 449, in wait_for
raise futures.TimeoutError()
concurrent.futures._base.TimeoutError
2020-06-07 08:29:18 WARNING (MainThread) [homeassistant.config_entries] Config entry for zha not ready yet. Retrying in 5 seconds.
2020-06-07 08:29:18 WARNING (MainThread) [zigpy_cc.api] Waiter timeout: <Waiter matcher=<Matcher type=CommandType.SRSP subsystem=Subsystem.SYS command=version payload={}> future=<Future cancelled> timeout=6000 sequence=None>
2020-06-07 08:29:24 ERROR (MainThread) [homeassistant.components.sensor] Error while setting up coronavirus platform for sensor
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 186, in _async_setup_platform
await asyncio.gather(*pending)
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 295, in async_add_entities
await asyncio.gather(*tasks)
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 446, in _async_add_entity
entity.async_write_ha_state()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 297, in async_write_ha_state
self._async_write_ha_state() # type: ignore
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 320, in _async_write_ha_state
state = self.state
File "/usr/src/homeassistant/homeassistant/components/coronavirus/sensor.py", line 55, in state
getattr(case, self.info_type) for case in self.coordinator.data.values()
File "/usr/src/homeassistant/homeassistant/components/coronavirus/sensor.py", line 55, in <genexpr>
File "/usr/local/lib/python3.7/site-packages/coronavirus/__init__.py", line 25, in current
return self.confirmed - self.deaths - self.recovered
TypeError: unsupported operand type(s) for -: 'int' and 'NoneType'
2020-06-07 08:29:37 ERROR (MainThread) [zigpy.application] Couldn't start application
2020-06-07 08:29:37 ERROR (MainThread) [homeassistant.components.zha.core.gateway] Couldn't start TI_CC: CC2531, CC2530, CC2652R, CC1352 etc, Texas Instruments ZNP protocol coordinator
2020-06-07 08:29:37 WARNING (MainThread) [homeassistant.config_entries] Config entry for zha not ready yet. Retrying in 10 seconds.
2020-06-07 08:29:37 WARNING (MainThread) [zigpy_cc.api] Waiter timeout: <Waiter matcher=<Matcher type=CommandType.SRSP subsystem=Subsystem.SYS command=version payload={}> future=<Future cancelled> timeout=6000 sequence=None>
2020-06-07 08:29:58 ERROR (MainThread) [zigpy.application] Couldn't start application
2020-06-07 08:29:58 ERROR (MainThread) [homeassistant.components.zha.core.gateway] Couldn't start TI_CC: CC2531, CC2530, CC2652R, CC1352 etc, Texas Instruments ZNP protocol coordinator
2020-06-07 08:29:58 WARNING (MainThread) [homeassistant.config_entries] Config entry for zha not ready yet. Retrying in 20 seconds.
2020-06-07 08:29:58 WARNING (MainThread) [zigpy_cc.api] Waiter timeout: <Waiter matcher=<Matcher type=CommandType.SRSP subsystem=Subsystem.SYS command=version payload={}> future=<Future cancelled> timeout=6000 sequence=None>
2020-06-07 08:30:25 ERROR (MainThread) [zigpy.application] Couldn't start application
2020-06-07 08:30:25 ERROR (MainThread) [homeassistant.components.zha.core.gateway] Couldn't start TI_CC: CC2531, CC2530, CC2652R, CC1352 etc, Texas Instruments ZNP protocol coordinator
2020-06-07 08:30:25 WARNING (MainThread) [homeassistant.config_entries] Config entry for zha not ready yet. Retrying in 40 seconds.
2020-06-07 08:30:26 WARNING (MainThread) [zigpy_cc.api] Waiter timeout: <Waiter matcher=<Matcher type=CommandType.SRSP subsystem=Subsystem.SYS command=version payload={}> future=<Future cancelled> timeout=6000 sequence=None>
2020-06-07 08:31:13 ERROR (MainThread) [zigpy.application] Couldn't start application
2020-06-07 08:31:13 ERROR (MainThread) [homeassistant.components.zha.core.gateway] Couldn't start TI_CC: CC2531, CC2530, CC2652R, CC1352 etc, Texas Instruments ZNP protocol coordinator
2020-06-07 08:31:13 WARNING (MainThread) [homeassistant.config_entries] Config entry for zha not ready yet. Retrying in 80 seconds.
2020-06-07 08:31:13 WARNING (MainThread) [zigpy_cc.api] Waiter timeout: <Waiter matcher=<Matcher type=CommandType.SRSP subsystem=Subsystem.SYS command=version payload={}> future=<Future cancelled> timeout=6000 sequence=None>
2020-06-07 08:32:41 ERROR (MainThread) [zigpy.application] Couldn't start application
2020-06-07 08:32:41 ERROR (MainThread) [homeassistant.components.zha.core.gateway] Couldn't start TI_CC: CC2531, CC2530, CC2652R, CC1352 etc, Texas Instruments ZNP protocol coordinator
2020-06-07 08:32:41 WARNING (MainThread) [homeassistant.config_entries] Config entry for zha not ready yet. Retrying in 80 seconds.
2020-06-07 08:32:41 WARNING (MainThread) [zigpy_cc.api] Waiter timeout: <Waiter matcher=<Matcher type=CommandType.SRSP subsystem=Subsystem.SYS command=version payload={}> future=<Future cancelled> timeout=6000 sequence=None>
2020-06-07 08:34:09 ERROR (MainThread) [zigpy.application] Couldn't start application
2020-06-07 08:34:09 ERROR (MainThread) [homeassistant.components.zha.core.gateway] Couldn't start TI_CC: CC2531, CC2530, CC2652R, CC1352 etc, Texas Instruments ZNP protocol coordinator
2020-06-07 08:34:09 WARNING (MainThread) [homeassistant.config_entries] Config entry for zha not ready yet. Retrying in 80 seconds.
2020-06-07 08:34:09 WARNING (MainThread) [zigpy_cc.api] Waiter timeout: <Waiter matcher=<Matcher type=CommandType.SRSP subsystem=Subsystem.SYS command=version payload={}> future=<Future cancelled> timeout=6000 sequence=None>
2020-06-07 08:35:37 ERROR (MainThread) [zigpy.application] Couldn't start application
2020-06-07 08:35:37 ERROR (MainThread) [homeassistant.components.zha.core.gateway] Couldn't start TI_CC: CC2531, CC2530, CC2652R, CC1352 etc, Texas Instruments ZNP protocol coordinator
2020-06-07 08:35:37 WARNING (MainThread) [homeassistant.config_entries] Config entry for zha not ready yet. Retrying in 80 seconds.
2020-06-07 08:35:37 WARNING (MainThread) [zigpy_cc.api] Waiter timeout: <Waiter matcher=<Matcher type=CommandType.SRSP subsystem=Subsystem.SYS command=version payload={}> future=<Future cancelled> timeout=6000 sequence=None>
2020-06-07 08:37:05 ERROR (MainThread) [zigpy.application] Couldn't start application
2020-06-07 08:37:05 ERROR (MainThread) [homeassistant.components.zha.core.gateway] Couldn't start TI_CC: CC2531, CC2530, CC2652R, CC1352 etc, Texas Instruments ZNP protocol coordinator
File "/usr/local/lib/python3.7/site-packages/zigpy_cc/zigbee/application.py", line 97, in startup
await self.form_network()
File "/usr/local/lib/python3.7/site-packages/zigpy_cc/zigbee/application.py", line 118, in form_network
self._api, self.version["product"], options, 0x0B84, backupPath
File "/usr/local/lib/python3.7/site-packages/zigpy_cc/zigbee/start_znp.py", line 262, in start_znp
expected_status=[0, 2],
File "/usr/local/lib/python3.7/site-packages/zigpy_cc/zigbee/start_znp.py", line 73, in validate_item
result = await znp.request(subsystem, command, item, expected_status)
2020-06-07 08:37:05 WARNING (MainThread) [homeassistant.config_entries] Config entry for zha not ready yet. Retrying in 80 seconds.
2020-06-07 08:37:05 WARNING (MainThread) [zigpy_cc.api] Waiter timeout: <Waiter matcher=<Matcher type=CommandType.SRSP subsystem=Subsystem.SYS command=osalNvRead payload={}> future=<Future cancelled> timeout=6000 sequence=None>
2020-06-07 08:38:33 ERROR (MainThread) [zigpy.application] Couldn't start application
2020-06-07 08:38:33 ERROR (MainThread) [homeassistant.components.zha.core.gateway] Couldn't start TI_CC: CC2531, CC2530, CC2652R, CC1352 etc, Texas Instruments ZNP protocol coordinator
2020-06-07 08:38:33 WARNING (MainThread) [homeassistant.config_entries] Config entry for zha not ready yet. Retrying in 80 seconds.
2020-06-07 08:38:33 WARNING (MainThread) [zigpy_cc.api] Waiter timeout: <Waiter matcher=<Matcher type=CommandType.SRSP subsystem=Subsystem.SYS command=version payload={}> future=<Future cancelled> timeout=6000 sequence=None>
2020-06-07 08:40:01 ERROR (MainThread) [zigpy.application] Couldn't start application
2020-06-07 08:40:01 ERROR (MainThread) [homeassistant.components.zha.core.gateway] Couldn't start TI_CC: CC2531, CC2530, CC2652R, CC1352 etc, Texas Instruments ZNP protocol coordinator
2020-06-07 08:40:01 WARNING (MainThread) [homeassistant.config_entries] Config entry for zha not ready yet. Retrying in 80 seconds.
2020-06-07 08:40:01 WARNING (MainThread) [zigpy_cc.api] Waiter timeout: <Waiter matcher=<Matcher type=CommandType.SRSP subsystem=Subsystem.SYS command=osalNvRead payload={}> future=<Future cancelled> timeout=6000 sequence=None>
2020-06-07 08:41:29 ERROR (MainThread) [zigpy.application] Couldn't start application
2020-06-07 08:41:29 ERROR (MainThread) [homeassistant.components.zha.core.gateway] Couldn't start TI_CC: CC2531, CC2530, CC2652R, CC1352 etc, Texas Instruments ZNP protocol coordinator
2020-06-07 08:41:29 WARNING (MainThread) [homeassistant.config_entries] Config entry for zha not ready yet. Retrying in 80 seconds.
2020-06-07 08:41:29 WARNING (MainThread) [zigpy_cc.api] Waiter timeout: <Waiter matcher=<Matcher type=CommandType.SRSP subsystem=Subsystem.SYS command=version payload={}> future=<Future cancelled> timeout=6000 sequence=None>
2020-06-07 08:44:15 WARNING (MainThread) [zigpy_cc.api] Waiter timeout: <Waiter matcher=<Matcher type=CommandType.AREQ subsystem=Subsystem.AF command=dataConfirm payload={'endpoint': 1, 'transid': 8}> future=<Future cancelled> timeout=10000 sequence=None>
2020-06-07 08:44:39 WARNING (MainThread) [zigpy_cc.api] Waiter timeout: <Waiter matcher=<Matcher type=CommandType.SRSP subsystem=Subsystem.AF command=dataRequest payload={}> future=<Future cancelled> timeout=6000 sequence=None>
2020-06-07 08:44:40 WARNING (MainThread) [zigpy_cc.api] Waiter timeout: <Waiter matcher=<Matcher type=CommandType.SRSP subsystem=Subsystem.AF command=dataRequest payload={}> future=<Future cancelled> timeout=6000 sequence=None>
2020-06-07 08:46:15 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection.2807399792] Error handling message: Timeout
2020-06-07 08:46:15 WARNING (MainThread) [zigpy_cc.api] Waiter timeout: <Waiter matcher=<Matcher type=CommandType.SRSP subsystem=Subsystem.ZDO command=mgmtPermitJoinReq payload={}> future=<Future cancelled> timeout=6000 sequence=None>
2020-06-07 08:48:49 WARNING (MainThread) [zigpy_cc.api] Waiter timeout: <Waiter matcher=<Matcher type=CommandType.SRSP subsystem=Subsystem.AF command=dataRequest payload={}> future=<Future cancelled> timeout=6000 sequence=None>
2020-06-07 08:48:55 WARNING (MainThread) [zigpy_cc.api] Waiter timeout: <Waiter matcher=<Matcher type=CommandType.SRSP subsystem=Subsystem.AF command=dataRequest payload={}> future=<Future cancelled> timeout=6000 sequence=None>
2020-06-07 08:49:01 WARNING (MainThread) [zigpy_cc.api] Waiter timeout: <Waiter matcher=<Matcher type=CommandType.SRSP subsystem=Subsystem.AF command=dataRequest payload={}> future=<Future cancelled> timeout=6000 sequence=None>
2020-06-07 08:49:04 WARNING (MainThread) [zigpy_cc.api] Waiter timeout: <Waiter matcher=<Matcher type=CommandType.SRSP subsystem=Subsystem.AF command=dataRequest payload={}> future=<Future cancelled> timeout=6000 sequence=None>
2020-06-07 08:49:10 WARNING (MainThread) [zigpy_cc.api] Waiter timeout: <Waiter matcher=<Matcher type=CommandType.SRSP subsystem=Subsystem.AF command=dataRequest payload={}> future=<Future cancelled> timeout=6000 sequence=None>
2020-06-07 08:49:15 WARNING (MainThread) [zigpy_cc.api] Waiter timeout: <Waiter matcher=<Matcher type=CommandType.SRSP subsystem=Subsystem.AF command=dataRequest payload={}> future=<Future cancelled> timeout=6000 sequence=None>
2020-06-07 08:49:20 WARNING (MainThread) [zigpy_cc.api] Waiter timeout: <Waiter matcher=<Matcher type=CommandType.SRSP subsystem=Subsystem.AF command=dataRequest payload={}> future=<Future cancelled> timeout=6000 sequence=None>
2020-06-07 08:49:25 WARNING (MainThread) [zigpy_cc.api] Waiter timeout: <Waiter matcher=<Matcher type=CommandType.SRSP subsystem=Subsystem.AF command=dataRequest payload={}> future=<Future cancelled> timeout=6000 sequence=None>
2020-06-07 09:29:24 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
File "/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py", line 111, in _handle_refresh_interval
await self.async_refresh()
File "/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py", line 177, in async_refresh
update_callback()
state = self.state
Hit the character limit, with a vengeance, final reply below.
