CC2538+CC2592 Raspberry PI UART adapter hat for sale
CC2538+CC2592 Raspberry PI UART adapter is available for sale here:
ZigBee CC2538+CC2592 Module coordinator for Raspberry Pi ZigDobby | eBay
Available for International shipping
A kit with antenna is available as well.
Hello Aleksei. I am extremely interested to get double of this adapter. But I could not find any review or any one tried it before. I am running CC5231 on z2m but not happy with the range and stability. Will this be working directly on HA with z2m? Will ir plug and play?
Thanks.
Hi sallwm,
That requires some configuration to start. Need to configure serial port setting on RPI. I’m prepping an image (instructions) for hassio now. But working with serial ports on RPI has never been to easy.
Once ready I’ll post it here.
In about 2 week (mid-late Febrary) i’m going to release more plug & play-ish solution. USB based, with the same hardware.
Thank you Aleksei. How to you compare this solution to the CC2652R stick in term of coverage and stability?
I don’t have cc2652 at hands, therefore can talk about it only from “theoretical” point of view.
  • 2652 has more ram, less flash. So it i expect it may handle larger amount of direct connections
  • 2538 has on-board USB controller, should be better for USB-stick based implementations.\
  • both can be combined with CC2592 for the range extension. Mine is combined, haven’t seen too many 2652 with 2592 though.
Stability - wise: it is all about firmware implementation, traffic, wifi, etc. Decision can be made only by trying both in same environment - can’t judge here.
What I’m hesitant about in CC2652 is that it is multi-protocol. Specialized things usually are a bit better than universal.
But I’m considering 2652 for the next version, especially if i’m able to join it with 2592.
Thanks. I have been looking for a stable solution with larger coverage. So far, I tried CC2531 with antenna and Conbee II. Conbee II is way better but I would like to stick with zigbee2mqtt which is not compatible with Conbee yet. I read a lot about many solution but still could not find one solution that most people agreed on. I need to have a robust system for a three levels house!
Hi Aleksei,
Is it ready now? I am interested in plug n playish zigbee USB with good range/coverage
