CC2652P + 3x Sonoff SNZB-02 + 1x Danfoss Ally issues
Hey!
Not sure what my issue could be specifically, but I’m experiencing a lot of dropouts and also a non-reactive TRV.
The Ally doesn’t seem to like to take in commands after it receives the first one after I reboot it. After that I get MAC_NO_ACK responses into the debug log.
Here’s a sample of me trying to adjust the setpoint from 22.5 to 23 degrees.
2021-11-15 00:09:34 DEBUG (MainThread) [zigpy.device] [0x8033] Extending timeout for 0x09 request
2021-11-15 00:09:34 DEBUG (MainThread) [zigpy_znp.api] Sending request: AF.DataRequestExt.Req(DstAddrModeAddress=AddrModeAddress(mode=<AddrMode.NWK: 2>, address=0x8033), DstEndpoint=1, DstPanId=0x0000, SrcEndpoint=1, ClusterId=513, TSN=9, Options=<TransmitOptions.SUPPRESS_ROUTE_DISC_NETWORK|ACK_REQUEST: 48>, Radius=30, Data=b'\x00\x09\x02\x12\x00\x29\xFC\x08')
2021-11-15 00:09:34 DEBUG (MainThread) [zigpy_znp.api] Received command: AF.DataRequestExt.Rsp(Status=<Status.SUCCESS: 0>)
2021-11-15 00:09:35 DEBUG (MainThread) [zigpy_znp.api] Received command: AF.DataConfirm.Callback(Status=<Status.MAC_NO_ACK: 233>, Endpoint=1, TSN=9)
2021-11-15 00:09:35 DEBUG (MainThread) [zigpy_znp.zigbee.application] Request failed (Unsuccessful request status code: <Status.MAC_NO_ACK: 233>), retry attempt 1 of 5
2021-11-15 00:09:36 DEBUG (MainThread) [zigpy_znp.api] Sending request: AF.DataRequestExt.Req(DstAddrModeAddress=AddrModeAddress(mode=<AddrMode.NWK: 2>, address=0x8033), DstEndpoint=1, DstPanId=0x0000, SrcEndpoint=1, ClusterId=513, TSN=9, Options=<TransmitOptions.SUPPRESS_ROUTE_DISC_NETWORK|ACK_REQUEST: 48>, Radius=30, Data=b'\x00\x09\x02\x12\x00\x29\xFC\x08')
2021-11-15 00:09:36 DEBUG (MainThread) [zigpy_znp.api] Received command: AF.DataRequestExt.Rsp(Status=<Status.SUCCESS: 0>)
2021-11-15 00:09:36 DEBUG (MainThread) [zigpy_znp.api] Received command: AF.DataConfirm.Callback(Status=<Status.MAC_NO_ACK: 233>, Endpoint=1, TSN=9)
2021-11-15 00:09:36 DEBUG (MainThread) [zigpy_znp.zigbee.application] Request failed (Unsuccessful request status code: <Status.MAC_NO_ACK: 233>), retry attempt 2 of 5
2021-11-15 00:09:37 DEBUG (MainThread) [zigpy_znp.api] Sending request: AF.DataRequestSrcRtg.Req(DstAddr=0x8033, DstEndpoint=1, SrcEndpoint=1, ClusterId=513, TSN=9, Options=<TransmitOptions.SUPPRESS_ROUTE_DISC_NETWORK|ACK_REQUEST: 48>, Radius=30, SourceRoute=[], Data=b'\x00\x09\x02\x12\x00\x29\xFC\x08')
2021-11-15 00:09:37 DEBUG (MainThread) [zigpy_znp.api] Received command: AF.DataRequestSrcRtg.Rsp(Status=<Status.SUCCESS: 0>)
2021-11-15 00:09:37 DEBUG (MainThread) [zigpy_znp.api] Received command: AF.DataConfirm.Callback(Status=<Status.MAC_NO_ACK: 233>, Endpoint=1, TSN=9)
2021-11-15 00:09:37 DEBUG (MainThread) [zigpy_znp.api] Sending request: ZDO.ExtRouteDisc.Req(Dst=0x8033, Options=<RouteDiscoveryOptions.UNICAST: 0>, Radius=30)
2021-11-15 00:09:37 DEBUG (MainThread) [zigpy_znp.api] Received command: ZDO.ExtRouteDisc.Rsp(Status=<Status.SUCCESS: 0>)
2021-11-15 00:09:38 DEBUG (MainThread) [zigpy_znp.zigbee.application] Request failed (Unsuccessful request status code: <Status.MAC_NO_ACK: 233>), retry attempt 3 of 5
2021-11-15 00:09:39 DEBUG (MainThread) [zigpy_znp.api] Sending request: AF.DataRequestExt.Req(DstAddrModeAddress=AddrModeAddress(mode=<AddrMode.NWK: 2>, address=0x8033), DstEndpoint=1, DstPanId=0x0000, SrcEndpoint=1, ClusterId=513, TSN=9, Options=<TransmitOptions.SUPPRESS_ROUTE_DISC_NETWORK|ACK_REQUEST: 48>, Radius=30, Data=b'\x00\x09\x02\x12\x00\x29\xFC\x08')
2021-11-15 00:09:39 DEBUG (MainThread) [zigpy_znp.api] Received command: AF.DataRequestExt.Rsp(Status=<Status.SUCCESS: 0>)
2021-11-15 00:09:39 DEBUG (MainThread) [zigpy_znp.api] Received command: AF.DataConfirm.Callback(Status=<Status.MAC_NO_ACK: 233>, Endpoint=1, TSN=9)
2021-11-15 00:09:39 DEBUG (MainThread) [zigpy_znp.zigbee.application] Request failed (Unsuccessful request status code: <Status.MAC_NO_ACK: 233>), retry attempt 4 of 5
2021-11-15 00:09:39 DEBUG (MainThread) [zigpy_znp.api] Sending request: AF.DataRequestExt.Req(DstAddrModeAddress=AddrModeAddress(mode=<AddrMode.IEEE: 3>, address=80:4b:50:ff:fe:3e:df:29), DstEndpoint=1, DstPanId=0x0000, SrcEndpoint=1, ClusterId=513, TSN=9, Options=<TransmitOptions.SUPPRESS_ROUTE_DISC_NETWORK|ACK_REQUEST: 48>, Radius=30, Data=b'\x00\x09\x02\x12\x00\x29\xFC\x08')
2021-11-15 00:09:39 DEBUG (MainThread) [zigpy_znp.zigbee.application] Request failed (Unsuccessful request status code: <Status.MAC_NO_ACK: 233>), retry attempt 5 of 5
2021-11-15 00:09:40 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0x8033:1:0x0201]: couldn't write {'occupied_heating_setpoint': 2300}: Request failed after 5 attempts: <Status.MAC_NO_ACK: 233>
2021-11-15 00:09:40 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0x8033:1:0x0201]: couldn't set heating setpoint
Most of the time it still reports in the measured temperature and heat demand.
Any thoughts?
Are these the only Zigbee devices you have ? Do you use an USB extension cable for your CC2652P ?
These are the only Zigbee devices. No extension on the CC2652P, directly in the top USB3 port of RPi4 4GB.
Try using an USB extension cable, and an USB 2.0 port.
Agree with Francis and would also recommend this to OP:
Used an extension and connected to the USB2 port and placed them about 70 cm apart, but no change, the Ally still responds with MAC_NO_ACK.
The Ally does not respond. That is what MAC_NO_ACK means.
With a Zigbee network of only a coordinator and no routing devices, you don’t have a mesh. What is the distance between the CC2652P and the Ally ?
About 5 meters with a thin wall in between, LQI shows above 50 stable.
Is that too poor of an LQI and I should get some wall plug to act as a router?
Anything simple/not too expensive that You’d recommend?
Is the Xiaomi Mi Smart Plug (model ZNCZ04LM) ok?
Sorry for reviving this old thread, but I just got myself a Sonoff zigbee receiver (Based on TI CC2652P + CP2102N), to replace an old receiver based on one of the early TI CCxxxx chipsets.
Before the new receiver, I had no issues with my TRV, or any other devices on the network.
After replacing it, every other device works just fine (a mix of sensors, a wall plug and a smart bulb) - but the Ally TRV keeps being a problem.
I haven’t tried with the extension cable, but the new receiver is plugged in to the exact same USB 3 port as the old receiver - with a wifi router placed right next to it.
Is this channel sensitivity more of a problem on newer Zigbee hardware?
My final solution was to get an Ikea Tradfri Repeater, now the Ally has 100+ LQI and stays accessible.
