CCS codes for the IOS app
I am using the ios app but the bar at the bottom isn’t showing the buttons. They are there but somewhere in my theme it is configured to have the same color as the bar. What are the theme options for the bar and bottons at the bottom?
This is much improved in the 2.0 beta by removal of the lower toolbar entirely. In 1.5.1, the variable you want to set is primary-color. Because your chosen primary-color is so similar to the default iOS toolbar color you are unable to see the buttons.
I was not aware that I had to manualy update the testflight app. There seems to be alot of changes! Thank you!
