Hello, I have some CCT IC LED strips with COB LEDs with a single data Pin, in my case I put 13, which are addressable and I have them with Wled but they don’t work very well for me as they flash and are not very stable, yesterday I tried putting them in with esphome and the truth is that they are more stable but I can’t get a configuration so that I can only select the type of whites and not the RGB color palette because to select the white colors, I have to move the RGB palette and it is not accurate at all. Any ESPhome configuration for these types of addressable LED strips? thank you so much
Hello there.
Did you manage to find a solution for this with esphome?
I got the same strips coming.
