nmparmar
(nmparmar)
1
I have a DVR with a number of cameras. It’s both onvif and RTSP capable. I have home assistant and Google Assistant ( though not integrated).
I want to be able to pull up the video feed from the DVR / Camera and push it to the Chromecast.
Has anyone done anything similar? Any suggestions on how best to achieve this?
tmjpugh
(Tmjpugh)
2
I found a script that takes video as input and converts to Chromecast streamable format using ffmpeg.
If I find it I will add here
EDIT
See this post
nmparmar
(nmparmar)
3
Thanks for the reply, this looks promising. So question, can this feed be invoked through google assistant?
tmjpugh
(Tmjpugh)
4
Yes/No
Yes, you can make this a switch in HA that GA can trigger.
No, don’t think you can call this directly from GA
nmparmar
(nmparmar)
5
Great, thank you. Will have a look into this.
