I have integrated both IP cameras and cameras running on a DVR via an RSTP stream. The IP cameras look great however i’m struggling with DVR streams. In the static image preview i’m getting odd “streaks”. Sometimes they are there, sometimes they are not. Sometimes its on one camera sometimes its on another.
I’m not using the stream function. I have tried that but the stream struggles to buffer well enough so i’m happy to have non stream version just to see whats going on. Is it something obvious that i’m missing?
Could it be a DVR issue? There is a secondary stream at a lower resolution but that has a similar output. When hooking into the stream via vlc there is a delay to start it but once its running its fine.
The DVR system is a cheap sansco system but it has a lot of settings i can adjust regarding the stream. If you need more info that would help please let me know.
The recorded video is fine when viewing direct on the DVR. I do have IP cams but they aren’t affected. Its only the DVR cams which are. There’s no direct stream from the cam as its via the DVR.
You are right its not a massive issue but if its an easy fix i’ll def want to give it a try.
The snapshot feature of my amcrest nvr seemed to always do this even when using the URL directly… lowering the quality in my camera settings would help a little. Ultimately changing to using FFMPEG and the RTSP stream instead of the amcrest component (which used the snapshot feature to get the image) I stopped having the issue awhile ago.
What are your camera settings in your configuration.yaml ? Brand of camera? Brand of DVR…
The DVR is a Sansco S4D4C1T. The cameras are branded sansco as well but I assume they are just a whitelablled enclosure with generic guts. I’ve adjusted the FFMPEG config to include -vf scale=640:480 that seems to have reduced the issue somewhat. Which is good. Three specific things have happened. It seems to display the thumbnail quicker (i am waiting less time for the initial image to appear), but the instances of streaks has reduced and the thumbnail seems to update quicker as well.
I’m not 100% sure what the -vf switch does but i’m assuming its adjusting the incoming stream to a lower quality which i’m guessing points to a stream quality/bandwidth issue.
I’m certain Lower framerate or resolution will improve this
Possibly Better HDD but I doubt this. I thinks R/W and transcode to video stream is creating issue…just play with this settings to get best mix quality/resolution/reduced streaking
