I specified my ccu2 in the configuration.yaml.
In Homeassistant I only see entities but no devices, so I can’t write automations.
Do I have to connect the CCU2 differently so that I can see the devices?
Thank u
Thank u
The old integration only provides entities. You can still do automations with those. Just a little less comfortable. If you want devices, you’ll have to switch to the new integration, which is available as a custom component.
thank you for your answer. Do you know what exactly I have to load? I have now bought an RFUSB to go from CCU2 to a Rasbeymatic. That might make the transition easier.
thanks, just saw the link now
It worst… thank you.
