Home Assistant 2022.10.1
Supervisor 2022.09.1
Operating System 9.0
Frontend 20221006.0 - latest
I am trying to get CEC Scanner working. I install the addon, ive restarted many times but iu keep seeing the below logged. The service then stops. Any ideas? My HA is plugged in to the screen with a HDMI cable.
s6-init] making user provided files available at /var/run/s6/etc…exited 0.
[s6-init] ensuring user provided files have correct perms…exited 0.
[fix-attrs.d] applying ownership & permissions fixes…
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts…
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[15:24:24] INFO: Starting CEC client scan…
autodetect FAILED
[cont-finish.d] executing container finish scripts…
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
[s6-finish] sending all processes the KILL signal and exiting.
Same here. I installed the add-on for the first time a few days ago. I’m running hass os on a bare metal x86 machine.
I connected the HDMI port on my motherboard to an AVR I use for audio only that does support HDMI CEC: my chromecast turns it on. Tried two different HDMI cables and two different HDMI ports on the AVR. The logs look the same whether I have an HDMI cable connected or not.
I’ve been poking around to see if there’s a way to find out of hass os is recognizing the HDMI hardware, but short of lugging a monitor over there and plugging it in, I’m coming up empty.
Home Assistant 2022.12.5
Supervisor 2022.11.2
Operating System 9.4
Frontend 20221213.0 - latest
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] done.
[services.d] done.
[22:17:35] INFO: Starting CEC client scan...
autodetect FAILED
[cont-finish.d] executing container finish scripts...
