I’ve multiple lights in the living room and I’m looking an option to automate them with Zigbee switch, looking different options I’ve found a Sonoff device, but looking to their description seems is more to be placed on the switch directly
My idea is to place it on the ceiling light (line in the power and out to the lights) - I had a RF switch mounted that way some time ago… but not sure if it will work the same with those zigbee switches.
Is this possible ? have someone some information about the wiring instructions ?
I think you would need two devices to control them independently. One device from plug to wall to desk lamp. One for the ceiling lamp. You will need a neutral wire in both places. You would not connect anything to the switches. You are limited to 10A for each sonoff device.
Wiring
If the neutrals are wired together then a jumper to Nin. Line in box to the line in (Lin) and load (Lout) to the lamp.
Not seeing your wiring, this is my best guess. YMMV I do not have this device so you will have to read the specs to confirm. I do own shellies and they work without being attached to a switch.
I found a different Sonoff device that could be the one you recommended for the lamp, for the ceiling what could you recommend ? (I’m using zigbee devices)
Many thanks!
With the video now is clear, it should work installing them I had previously with DiO device without use the wall switch - according the installation and explanations I see
