Cellular data = NSURLErrorDomain -1003
My HA has always worked perfect for more than 8 years, and now, i don’t know exactly when ( maybe after changed my iphone ) i could see that my HA instance isn’t working when using my cellular data, and no matter if i use a vpn to my private network at home, i get the error:
A server with the specified hostname could not be found.
Nothing has changed in my HA config, the only different thing in my setup is the new phone, that is correctly configurated as the last one! (iphone Xs - to 15)
I’m not a newbie HA user, already did everything i could, i’ve 2 instances os HA running, (one in EU other in SA) and sometimes when i reboot the cell phone, one works, and sometimes the other, but never both at same time!
And when i’m using a wifi network, doesn’t matter if is my private network at home, or my network at work, it works without issues! So the problem is only when using cellular data!
And no matter if i use the APP or try to access thru any web browser! No way to connect !!!
Anybody had the same problem?
(tested ping from my cell phone, the external ip addr using the cellular data, and i got no errors, no packet loss!)
