Hi
I have a very simple webpage card that I would like to center horizontally within the card to remove the white space on the right hand side:
Very basic card currently:
type: iframe
url: >-
https://services.metservice.com/weather-widget/widget?params=white|medium|portrait|days-3|classic&loc=auckland&type=urban
aspect_ratio: 50%
I do have layout-card installed, but I haven’t had much luck with finding out anything around centering.
I know it’ll be straightforward…
On a related tangent, is scaling this down a little an option too?
Help much appreciated!
If you only need to center the webpage in the card (not stretch) - then probably this may be fixed by card-mod. Go to Code Inspector in your browser and play with alignment. Cannot provide you a ready solution now, far away from a PC for a while.
Thanks.
Through trial and error I’ve come up with this to better make use of the space:
type: custom:mod-card
style:
hui-horizontal-stack-card$: |
hui-iframe-card {
width: 24%;
flex: auto !important;
gauge-card {
card:
type: horizontal-stack
cards:
- type: iframe
url: >-
aspect_ratio: 58%
- type: gauge
entity: sensor.ble_temperature_outdoor
severity:
green: 0
yellow: 25
red: 29
min: 10
max: 35
Probably still find a better use of the right-hand portion in time.
Am I doing this correctly?
Any suggestions?
