Centering entities/items in cards (horizontal layout/grid)
Hi there,
I’ve looked through various threads here and on reddit and haven’t found what I’m looking for, so I hope somebody can help. I’ve tried nesting this in a grid and a horizontal card and I’ve tried working with various CSS properties (to the best of my limited abilities).
What I’m looking for: The svg (floorplan card) on the left side of the dashboard is currently aligned to the top of the “page”. Ideally, I’d like it to center itself so that it’s less obvious when the tabs on the right side (alarm panel, garbage pickups, open windows, turned-on lights, etc) are “longer” than the svg-file is high. I could circumvent this by simply increasing the height of the svg-file, but I fear that doing so will make the svg-file look “too tall” 90% of the time.
Alternatively - if possible - the white background of the svg-file would scale to the height of the right side. So that the image of the house itself would be centered but the white background would grow so that visually, both sides are of equal heights.
Here’s my YAML:
type: horizontal-stack
cards:
  - type: custom:floorplan-card
    full_height: false
    config:
      image: /local/floorplan/examples/home/haus3.1.svg
      stylesheet: /local/floorplan/examples/home/home.css
      defaults:
        hover_action: null
        tap_action: null
      rules:
        - entity: ''
          tap_action:
            action: navigate
            navigation_path: /lovelace-kiosk/roomplan_eg
          element: floor.eg
        - entity: ''
          tap_action:
            action: navigate
            navigation_path: /lovelace-kiosk/dachgeschoss
          element: floor.dg
# The following entity is only a placeholder for a video-doorbell I want to get later on;
# whenever that's the case, the doorbell's feed would appear
# instead of the vaccume's map.
        - entity: ''
          element: doorbell
          tap_action:
            action: call-service
            service: browser_mod.popup
            service_data:
              content:
                type: picture-entity
                entity: camera.xiaomi_cloud_map_extractor
                camera_view: live
                aspect_ratio: '1:1'
                style:
                  width: 100%
                  height: 100%
                  align-self: center
                  justify-self: center
                  display: flex
  - type: vertical-stack
    cards:
      - type: custom:mushroom-chips-card
        chips:
          - type: template
            content: |2-
                    {{ as_timestamp(states('sensor.date_time_iso')) | timestamp_custom('%A, der %d.
                    %B %Y @ %H:%M Uhr; KW %W') | replace("January","Januar")| replace("February","Februar")| replace("March","März")| replace("May","Mai")| replace("June","Juni")| replace("July","Juli")| replace("October","Oktober")| replace("December","Dezember")| replace("Monday","Montag") | replace("Tuesday","Dienstag") | replace("Wednesday","Mittwoch") | replace("Thursday","Donnerstag") | replace("Friday","Freitag") | replace("Saturday","Samstag") | replace("Sunday","Sonntag")}}
            picture: ''
            icon: mdi:calendar-clock
            double_tap_action:
              action: none
            tap_action:
              action: none
            hold_action:
              action: none
        alignment: center
        chips:
          - type: conditional
            conditions:
              - entity: input_boolean.wertstoff_on
                state: 'on'
            chip:
              type: entity
              entity: sensor.wertstoff
              double_tap_action:
                action: none
              content_info: name
              icon_color: yellow
              tap_action:
                action: none
              hold_action:
                action: none
          - type: conditional
            conditions:
              - entity: input_boolean.restmull_on
                state: 'on'
            chip:
              type: entity
              entity: sensor.restmuell
              double_tap_action:
                action: none
              content_info: name
              icon_color: black
              tap_action:
                action: none
              hold_action:
                action: none
          - type: conditional
            conditions:
              - entity: input_boolean.bio_on
                state: 'on'
            chip:
              type: entity
              entity: sensor.biomuell
              double_tap_action:
                action: none
              content_info: name
              icon_color: green
              tap_action:
                action: none
              hold_action:
                action: none
        alignment: center
        chips:
          - type: weather
            entity: weather.dwd_weather_berlin_tegel
            show_conditions: true
            show_temperature: true
          - type: entity
            entity: sensor.s_bahn
          - type: entity
            entity: sensor.ersatzverkehr_u6
            icon: mdi:train-variant
            use_entity_picture: false
        alignment: center
      - type: custom:tabbed-card
        attributes:
          isFadingIndicator: true
        options: {}
        tabs:
          - card:
              type: custom:mushroom-alarm-control-panel-card
              entity: alarm_control_panel.home_alarm
              states:
                - armed_home
                - armed_away
              fill_container: false
              show_keypad: true
            attributes:
              label: Alarm
              icon: mdi:shield-home
          - card:
              cards:
                - type: entities
                  entities:
                    - type: custom:hui-element
                      label: Müll
                      card_type: vertical-stack
                      cards:
                        - type: markdown
                          content: |2-
                             ## <ha-icon icon="mdi:trash-can"></ha-icon> Müllabholung
                             {% set date_1 = states.sensor.abfallnaechster_2.attributes | first |
                             as_timestamp %} {% set date_2 = states.sensor.biomuell.attributes | first
                             | as_timestamp %} {% set date_3 = states.sensor.restmuell.attributes |
                             first | as_timestamp %} {% set date_4 = states.sensor.wertstoff.attributes
                             {% set entity_1 = "sensor.abfallnaechster_2" %} {% set entity_2 =
                             "sensor.biomuell" %} {% set entity_3 = "sensor.restmuell" %} {% set
                             entity_4 = "sensor.wertstoff" %}
                             {% set type_1 = states.sensor.abfallnaechster_2.attributes.values() |
                             first %} {% set type_2 = states.sensor.biomuell.attributes.values() |
                             first %} {% set type_3 = states.sensor.restmuell.attributes.values() |
                             first %} {% set type_4 = states.sensor.wertstoff.attributes.values() |
                             first %}
                             {% set dict_1 = date_1,type_1 %} {% set dict_2 = date_2,type_2 %} {% set
                             dict_3 = date_3,type_3 %} {% set dict_4 = date_4,type_4 %}
                             {% set dict_11 = date_1,entity_1 %} {% set dict_12 = date_2,entity_2 %} {%
                             set dict_13 = date_3,entity_3 %} {% set dict_14 = date_4,entity_4 %}
                             {% set type =  ([dict_1, dict_2, dict_3, dict_4] | min)[1] %} {% set date
                             = (([dict_11, dict_12, dict_13, dict_14] | min)[0]) %} {% set entity =
                             ([dict_11, dict_12, dict_13, dict_14] | min)[1] %}
                             Die nächste Abholung ist der <b>{{type | replace("Hausabfall", "Restmüll")
                             | replace("Biomuell", "Biomüll") | replace("Biogut", "Biomüll") }}</b>, am
                             <b> {{date | timestamp_custom("%A</b>, den %d. %b. %Y") |
                             replace("Monday", "Montag") | replace("Tuesday", "Dienstag") |
                             replace("Wednesday", "Mittwoch") | replace("Thursday", "Donnerstag") |
                             replace("Friday", "Freitag") | replace("Saturday", "Samstag") |
                             replace("Sunday", "Sonntag") | replace("Mar", "Mrz") | replace("May",
                             "Mai") | replace("Oct", "Okt") | replace("Dec", "Dez") }} ({{
                             states(entity) | replace("in 0 Tagen", "<b>heute</b>") | replace("in 1
                             Tagen", "<b>morgen</b>")}}).
                        - type: entities
                          entities:
                            - entity: sensor.restmuell
                            - entity: sensor.biomuell
                            - entity: sensor.wertstoff
                              secondary_info: none
            attributes:
              label: Müll
              icon: mdi:trash-can
          - card:
              type: custom:auto-entities
              show_empty: true
              card:
                show_name: true
                show_icon: true
                show_state: true
                type: glance
                title: Lichter - an
                state_color: true
              filter:
                include:
                  - domain: light
                    state: 'on'
                    options:
                      tap_action:
                        action: toggle
                exclude:
                  - group: light.einzellichter
                  - entity_id: light.einzellichter
                  - integration: browser_mod
            attributes:
              label: Lichter
              icon: mdi:lightbulb
# The auto-entity card for doors/windows isn't programmed yet. Placeholder.
         - card:
              show_empty: true
              card:
                show_name: true
                show_icon: true
                show_state: true
                type: glance
                title: ''
                state_color: true
              filter:
                include:
                  - group: Türen
                    state: 'on'
                    options:
                      tap_action:
                        action: toggle
            attributes:
              label: Fenster & Türen
              icon: mdi:door-open
    view_layout:
      position: sidebar
Thank you for your help! If there’s any additional info you need, let me know.
