I have been reading through the documentation and have tried some installs on CentOS 7, and continue to run into issues/errors when trying to launch hass.
I was wondering if there were any guides for CentOS 7 and Home Assistant. The instructions seem pretty straight forward but are very generic.
I tried it as well. Centos doesnât seem to setup python correctly. As best I can tell, only root can run python since the libraries are all installed in directories owned by root.
rh-python35-python-pip-7.1.0-2.el7.noarch : A tool for installing and managing Python packages
Repo : centos-sclo-rh
Matched from:
Filename : /opt/rh/rh-python35/root/usr/lib/python3.5/site-packages/pip
Filename : /opt/rh/rh-python35/root/usr/bin/pip
I know this is old, but if it might help others using CentOS 7. The lib files are readable by your homeassistant user, you just need to update the LD_LIBRARY_PATH variable for that user. I did it by adding the following line at /home/homeassistant/.bashrc (adjust depending on your username and home dir):
Okay, so adding the variable to homassistantâs .bashrc only worked for an interactive shell, but starting in the systemd service was still giving the same library error. I was able to fix it by updating ld.so.conf. I created a new file /etc/ld.so.conf.d/libpython35.conf and added the following line:
I was able to get it running once in a remote putty session to my home linux box.
Now when I try to run it again directly on the linux box
[xxx@LinuxServer /]$ $HOME/homeassistant/bin/hass
/home/xxx/homeassistant/bin/python3: error while loading shared libraries: libpython3.5m.so.rh-python35-1.0: cannot open shared object file: No such file or directory
I got it running again but the log files show errors. Anyone know how to fix these errors? There is a fix in debian in the troubleshooting section to fix the discovery but nothing for Centos.
2017-11-20 14:34:28 WARNING (MainThread) [homeassistant.setup] Setup of sensor is taking over 10 seconds.
2017-11-20 14:34:31 ERROR (Thread-5) [homeassistant.util.package] Unable to install package netdisco==1.2.3: Command â/root/homeassistant/bin/python3 -u -c âimport setuptools, tokenize;file=â/tmp/pip-build-i6swgk0e/netifaces/setup.pyâ;f=getattr(tokenize, âopenâ, open)(file);code=f.read().replace(â\r\nâ, â\nâ);f.close();exec(compile(code, file, âexecâ))â install --record /tmp/pip-ge89j9uh-record/install-record.txt --single-version-externally-managed --compile --install-headers /root/homeassistant/include/site/python3.5/netifacesâ failed with error code 1 in /tmp/pip-build-i6swgk0e/netifaces/
2017-11-20 14:34:31 ERROR (MainThread) [homeassistant.setup] Not initializing discovery because could not install dependency netdisco==1.2.3
2017-11-20 14:34:31 ERROR (MainThread) [homeassistant.setup] Setup failed for discovery: Could not install all requirements.
Hi Guys i am also getting the same error but permission denied
httpd: Syntax error on line 43 of /etc/httpd/conf/httpd.conf: Cannot load modules/mod_wsgi.so into server: libpython3.5m.so.1.0: cannot open shared object file: Permission denied
