Greetings from Germany…
I already have an automation that changes mine from “manual-summer” to “automatic-automatic”
- Heating circuit mode → between manual and automatic
- Heating circuit setting → between summer, automatic and winter
If the temperature falls below 3°C on the specified thermostat, I switch the heating to “automatic-automatic”
If the temperature of 6°C is then exceeded on the specified thermostat, I switch the heating back to “Manual-Summer”
So far so good, it works.
Now I want that.
When the temperature drops below 3°C, the heating only switches to “automatic-automatic” if the heating is in “manual-summer” mode.
It should also be queried if I only switch the heating to “manual-summer” when exceeding 6°C if it was previously switched to “automatic-automatic” at 3°C. Otherwise not.
It could be that I have changed this befor, or the outside temperature is below -10°C, then the heating switches automatically to “automatic-automatic”. In this case, of course, I do not want the heating to be switched off (antifreeze)
Unfortunately, I don’t know enough about this to realize this on my own, so I’m asking for your support.
Here is my automation below 3°C:
alias: Frostüberwachung Räumle gestartet unter 3°C, Heizung Eingeschaltet. <--- means below 3°C
description: Frost Gefahr !!! Temperatur im Räumle unter 3°C, Heizung Eingeschaltet.
- type: temperature
platform: device
device_id: 9b2c84506323c96be1a83a9d334a1a73
entity_id: sensor.lumi_lumi_weather_temperature_2
domain: sensor
below: 3
for:
hours: 0
minutes: 5
seconds: 0
condition: []
- service: notify.whatsappalex
title: Frost Gefahr !!! Temperatur im Räumle unter 3°C, Heizung Eingeschaltet.
message: Frost Gefahr !!! Temperatur im Räumle unter 3°C, Heizung Eingeschaltet.
- device_id: 127ffdc1c800018393ac8d858b189002
domain: select
entity_id: select.thermostat_hk1_set_summer_mode
type: select_option
option: auto
domain: select
entity_id: select.thermostat_hk1_mode
type: select_option
option: auto
mode: single
Here is my automation above 6°C:
alias: Frostüberwachung Räumle aufgehoben über 6°C, Heizung Ausgeschaltet.
description: Keine Frost Gefahr !!! Temperatur im Räumle über 6°C, Heizung Ausgeschaltet.
- type: temperature
platform: device
domain: sensor
for:
hours: 0
minutes: 5
seconds: 0
above: 6
condition: []
title: >-
Ausgeschaltet.
message: >-
Keine Frost Gefahr mehr !!! Temperatur im Räumle über 6°C, Heizung
Ausgeschaltet.
domain: select
type: select_option
option: Sommer
domain: select
type: select_option
option: Manuell
mode: single
