I am new to Home Assistant and trying to configure my first automation. I have a Centralite 3315-G water detector. I can’t seem to get it to fire an event when moisture is detected. I have watched the logs trying to determine what changes between detecting moisture and no moisture.
These are the lines in the logger that change between the two states:
[zigpy_deconz.api] APS data indication response: [32, <DeviceState.APSDE_DATA_REQUEST_SLOTS_AVAILABLE|2: 34>, <DeconzAddress address_mode=ADDRESS_MODE.NWK address=0x0000>, 1, <DeconzAddress address_mode=ADDRESS_MODE.NWK address=0x9ca3>, 1, 260, 1280, b'\tW\x00 \x00\x00\x00\x00\x00', 0, 175, 236, 77, 129, 0, 0, -88]
[zigpy.zcl] [0x9CA3:1:0x0500] Received ZCL frame: b'\tW\x00 \x00\x00\x00\x00\x00'
[zigpy.zcl] [0x9CA3:1:0x0500] Decoded ZCL frame header: ZCLHeader(frame_control=FrameControl(frame_type=<FrameType.CLUSTER_COMMAND: 1>, is_manufacturer_specific=0, direction=<Direction.Client_to_Server: 1>, disable_default_response=0, reserved=0, *is_cluster=True, *is_general=False, *is_reply=True), tsn=87, command_id=0, *direction=<Direction.Client_to_Server: 1>, *is_reply=True)
[zigpy.zcl] [0x9CA3:1:0x0500] Decoded ZCL frame: IasZone:status_change_notification(zone_status=<ZoneStatus.Restore_reports: 32>, extended_status=<bitmap8.0: 0>, zone_id=0, delay=0)
[zigpy.zcl] [0x9CA3:1:0x0500] Received command 0x00 (TSN 87): status_change_notification(zone_status=<ZoneStatus.Restore_reports: 32>, extended_status=<bitmap8.0: 0>, zone_id=0, delay=0)
[zigpy.zcl] [0x9CA3:1:0x0500] Sending reply header: ZCLHeader(frame_control=FrameControl(frame_type=<FrameType.GLOBAL_COMMAND: 0>, is_manufacturer_specific=False, direction=<Direction.Client_to_Server: 1>, disable_default_response=1, reserved=0, *is_cluster=False, *is_general=True, *is_reply=True), tsn=87, command_id=<GeneralCommand.Default_Response: 11>, *direction=<Direction.Client_to_Server: 1>, *is_reply=True)
[zigpy.zcl] [0x9CA3:1:0x0500] Sending reply: Default_Response(command_id=0, status=<Status.SUCCESS: 0>)
[homeassistant.components.zha.core.channels.base] [0x9CA3:1:0x0500]: Updated alarm state: ZoneStatus.0
[zigpy_deconz.zigbee.application] Sending Zigbee request with tsn 87 under 101 request id, data: b'18570b0000'
[zigpy_deconz.api] 'aps_data_indication' response from <DeconzAddress address_mode=ADDRESS_MODE.NWK address=0x9ca3>, ep: 1, profile: 0x0104, cluster_id: 0x0500, data: b'095700200000000000'
[zigpy_deconz.api] Command Command.aps_data_request (20, 101, <DeconzSendDataFlags.NONE: 0>, <DeconzAddressEndpoint address_mode=2 address=0x9CA3 endpoint=1>, 260, 1280, 1, b'\x18W\x0b\x00\x00', <DeconzTransmitOptions.USE_NWK_KEY_SECURITY: 2>, 0)
[zigpy_deconz.uart] Send: 0x121a001b001400650002a39c010401000501050018570b00000200
and this:
[zigpy_deconz.api] APS data indication response: [32, <DeviceState.APSDE_DATA_REQUEST_SLOTS_AVAILABLE|2: 34>, <DeconzAddress address_mode=ADDRESS_MODE.NWK address=0x0000>, 1, <DeconzAddress address_mode=ADDRESS_MODE.NWK address=0x9ca3>, 1, 260, 1280, b'\tV\x00!\x00\x00\x00\x00\x00', 0, 175, 188, 77, 129, 0, 0, -89]
[zigpy.zcl] [0x9CA3:1:0x0500] Received ZCL frame: b'\tV\x00!\x00\x00\x00\x00\x00'
[zigpy.zcl] [0x9CA3:1:0x0500] Decoded ZCL frame header: ZCLHeader(frame_control=FrameControl(frame_type=<FrameType.CLUSTER_COMMAND: 1>, is_manufacturer_specific=0, direction=<Direction.Client_to_Server: 1>, disable_default_response=0, reserved=0, *is_cluster=True, *is_general=False, *is_reply=True), tsn=86, command_id=0, *direction=<Direction.Client_to_Server: 1>, *is_reply=True)
[zigpy.zcl] [0x9CA3:1:0x0500] Decoded ZCL frame: IasZone:status_change_notification(zone_status=<ZoneStatus.Restore_reports|Alarm_1: 33>, extended_status=<bitmap8.0: 0>, zone_id=0, delay=0)
[zigpy.zcl] [0x9CA3:1:0x0500] Received command 0x00 (TSN 86): status_change_notification(zone_status=<ZoneStatus.Restore_reports|Alarm_1: 33>, extended_status=<bitmap8.0: 0>, zone_id=0, delay=0)
[zigpy.zcl] [0x9CA3:1:0x0500] Sending reply header: ZCLHeader(frame_control=FrameControl(frame_type=<FrameType.GLOBAL_COMMAND: 0>, is_manufacturer_specific=False, direction=<Direction.Client_to_Server: 1>, disable_default_response=1, reserved=0, *is_cluster=False, *is_general=True, *is_reply=True), tsn=86, command_id=<GeneralCommand.Default_Response: 11>, *direction=<Direction.Client_to_Server: 1>, *is_reply=True)
[homeassistant.components.zha.core.channels.base] [0x9CA3:1:0x0500]: Updated alarm state: ZoneStatus.Alarm_1
[zigpy_deconz.zigbee.application] Sending Zigbee request with tsn 86 under 100 request id, data: b'18560b0000'
[zigpy_deconz.api] 'aps_data_indication' response from <DeconzAddress address_mode=ADDRESS_MODE.NWK address=0x9ca3>, ep: 1, profile: 0x0104, cluster_id: 0x0500, data: b'095600210000000000'
[zigpy_deconz.api] Command Command.aps_data_request (20, 100, <DeconzSendDataFlags.NONE: 0>, <DeconzAddressEndpoint address_mode=2 address=0x9CA3 endpoint=1>, 260, 1280, 1, b'\x18V\x0b\x00\x00', <DeconzTransmitOptions.USE_NWK_KEY_SECURITY: 2>, 0)
[zigpy_deconz.uart] Send: 0x1217001b001400640002a39c010401000501050018560b00000200
I see that the alarm state: ZoneStatus goes between ZoneStatus.0 to ZoneStatus.Alarm_1
When setting up the automation the only entities that I have are:
There is not an alarm state.
This is my current yaml configuration:
platform: state
entity_id:
- binary_sensor.water_heater_iaszone
to: Alarm_1
Am I going about this the wrong way?
