Oh well this is great. So my SSL certificate has expired, so now I can’t access anything?! What am I supposed to do? Web frontend says ‘trying to connect’ - why?
I can’t ssh to it either, because of some docker weirdness I guess. Help!
because your trying to connect from another device
does that mean your running docker ? , on a device you can’t access via an attached monitor/keyboard ?
Yes, HA OS on a Pi, pretty standard no? Don’t tell me everyone else has monitors hooked up to their pis?
Ok am consoled on. WHat now, no nano? How am i supposed to edit files? (Don’t say vi!)
Nano works in my HAOS.
Weird. I even did a find / -name nano
- nothing
It’s in /usr/bin
Are you sure you’re running HAOS?
Nope, thats not my impression
try
ha info
… im not familiar with HAOS, so i don’t know if you get direct access to ha console commands
PS: I think you should
if so
ha inf
ha --help ( or just --h ) # read all about it ! , you can use --h after each command-string ( ha net --help etc )
I have 2023.3.1 as not updated yet. Definitely HAOS. And no nano in /usr/bin!
I wont say it, but you might “need” it
nano is standard for HAOS … so not sure what you have installed!
Anyway just use http://your HA IP:8123 - problem solved IF you are in the house…
How did you install Home Assistant?
That’s one, but probably more important is: How was the SSL certificate installed (and where) in the first place?
If you set up SSL in configuration.yaml you can’t use http anymore, hence the issue.
I can’t actually remember how I installed it. I usually use acme.sh and that sets up a cron job. So it’s quite possible that it didn’t manage to set cron up for whatever reason. It’s usually bullet proof, but I’m no docker engineer so something I don’t understand probably stopped it from working.
Yes you can … I can access locally without https and also locally with https. Not sure what you have done!!
Odd, it definitely didn’t work for me. I had two extra lines under http:
in my configuration.yaml - one for the cert, and one for the key. What does your config look like?
Mine looks like this
http:
ip_ban_enabled: false
login_attempts_threshold: 1
use_x_forwarded_for: true
I would recommend (if you get in) you use this add-on
But at the end of the day, if you can ssh in just remove your https config from the configuration yaml and restart, use the above add-on and you won’t have to worry about it ever again (it does all the renewals etc.)
No, you can’t. You very likely have a reverse proxy (nginx?) doing the SSL termination.
If you configure the certificate in configuration.yaml
, you can only do SSL.
