I just added cert_expiry and a couple of my sites but after reboot lots of log errors:
2020-01-25 11:47:53 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 109, in async_init
result = await self._async_handle_step(flow, flow.init_step, data)
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 172, in _async_handle_step
result: Dict = await getattr(flow, method)(user_input)
File "/usr/src/homeassistant/homeassistant/components/cert_expiry/config_flow.py", line 116, in async_step_import
return await self.async_step_user(user_input)
File "/usr/src/homeassistant/homeassistant/components/cert_expiry/config_flow.py", line 79, in async_step_user
if await self._test_connection(user_input):
File "/usr/src/homeassistant/homeassistant/components/cert_expiry/config_flow.py", line 50, in _test_connection
get_cert, host, user_input.get(CONF_PORT, DEFAULT_PORT)
File "/usr/src/homeassistant/homeassistant/components/cert_expiry/helper.py", line 12, in get_cert
with socket.create_connection(address, timeout=TIMEOUT) as sock:
File "/usr/local/lib/python3.7/socket.py", line 728, in create_connection
raise err
File "/usr/local/lib/python3.7/socket.py", line 716, in create_connection
sock.connect(sa)
ConnectionRefusedError: [Errno 111] Connection refused
File "/usr/src/homeassistant/homeassistant/components/cert_expiry/helper.py", line 13, in get_cert
with ctx.wrap_socket(sock, server_hostname=address[0]) as ssock:
File "/usr/local/lib/python3.7/ssl.py", line 423, in wrap_socket
session=session
File "/usr/local/lib/python3.7/ssl.py", line 870, in _create
self.do_handshake()
File "/usr/local/lib/python3.7/ssl.py", line 1139, in do_handshake
self._sslobj.do_handshake()
ssl.SSLCertVerificationError: [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: unable to get local issuer certificate (_ssl.c:1076)
File "/usr/src/homeassistant/homeassistant/components/cert_expiry/config_flow.py", line 60, in _test_connection
if "doesn't match" in err.args[0]:
Don’t really want to share my URL’s so not sure it’s value add but my sensor_ssl.yaml file:
- platform: cert_expiry
name: Smart Home Cert
host: <address for HA>
port: 8123
name: Home Server Cert
host: <address for a remote access server>
port: 443
for both of the above it’s just the server address, no https or anything.
And note these are GoDaddy certs not like DuckDNS or whatever.
