Certificate Expiry Checker - Run Action(s) (notifications) if certificates are about to expire
Import Certificate Expiry Checker blueprint to your Home Assistant.
The blueprint will return an array of dictionaries, which can be referenced using {{items}}. This way you can gain greater control over how the output should be handled.
An example of the returned data:
    "host": "portainer.example.com",
    "port": "9443",
    "rel_time": "9 days",
    'is_valid': True,
    "entity_id": "sensor.cert_expiry_timestamp_portainer_example_com_9443",
    "state": "2023-02-24T20:24:44+00:00"
    "host": "proxmox.example.com",
    "port": "8006",
    "rel_time": "1 day",
    'is_valid': True,
    "entity_id": "sensor.cert_expiry_timestamp_proxmox_example_com_8006",
    "state": "2023-02-16T23:06:53+00:00"
    "host": "www.example.com",
    "port": 443,
    'is_valid': True,
    "entity_id": "sensor.cert_expiry_timestamp_www_example_com",
    "state": "2023-02-24T20:19:17+00:00"
An action example which sends an HTML-formatted e-mail:
service: notify.smtp_gmail
  title: Certificates expiring soon
  message: |
    The following monitored certificates
      will expire soon:
    html: |
      <!DOCTYPE html> <html>
        <head>
          <meta charset="UTF-8">
          <meta http-equiv="Content-Type" content="text/html; charset=UTF-8">
          <meta name="viewport" content="width=device-width, initial-scale=1.0">
          <title>Certificates expiring soon</title>
        </head>
        <body>
          <p>The following monitored certificates will expire soon:</p>
          {% for item in items %}
          <p><a href="https://{{item.host}}:{{item.port}}"><span class="cert-expiry-host">{{item.host}}</span>:<span class="cert-expiry-port">{{item.port}}</span></a> expires in <span class="cert-expiry-time">{{item.rel_time}}</span>.</p>
          {% endfor %}
        </body>
      </html>
Another action example which creates a persistent notification:
service: notify.persistent_notification
  message: |
      <a href="https://{{item.host}}:{{item.port}}"><b>{{item.host}}:{{item.port}}</b></a> {{item.error}}.
    {% endfor %}
Please find the blueprint on Github:
The fine print:
I am not a programmer and I have little to no experience with YAML or Jinja2, so I have probably made several basic mistakes. If you find any mistakes, feel free to point them out, preferably with explanations and corrections for me to learn from :slight_smile:
I have published the code on Github, where you are welcome to clone/copy/whatever-it-is-called (I am no Github guru either), make pull requests (hopefully I will figure out how that works then) etc.
Changed the attribute “relative_time” to “rel_time” to avoid conflicts with the “relative_time” function.
Updated the action examples.
Is this still working?
The sensors currently look like this:
sensor.sub_domain_tld_cert_expiry
But when I look at your blueprint it seems to filter for:
selectattr(‘entity_id’, ‘match’, ‘^sensor.cert_expiry_timestamp’) %}
