I have regular installs on seven Pi’s (not Docker because HA is integrated with other stuff on the Pi), and I tried to do an upgrade to the latest version. But they all say the same, can anybody help me out with what I need to do here? It says a lot of adding directories to a variable, but I think the whole thing should work automatic with the ```
pip3 install --upgrade homeassistant
Collecting pycparser (from cffi!=1.11.3,>=1.8->cryptography==2.5->homeassistant)
Using cached https://www.piwheels.org/simple/pycparser/pycparser-2.19-py2.py3-none-any.whl
Building wheels for collected packages: cffi
Running setup.py bdist_wheel for cffi ... error
Complete output from command /usr/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-build-zl92_0cc/cffi/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" bdist_wheel -d /tmp/tmpfre7pglzpip-wheel- --python-tag cp35:
Package libffi was not found in the pkg-config search path.
Perhaps you should add the directory containing `libffi.pc'
to the PKG_CONFIG_PATH environment variable
No package 'libffi' found
running bdist_wheel
running build
running build_py
creating build
creating build/lib.linux-armv7l-3.5
creating build/lib.linux-armv7l-3.5/cffi
copying cffi/backend_ctypes.py -> build/lib.linux-armv7l-3.5/cffi
copying cffi/error.py -> build/lib.linux-armv7l-3.5/cffi
copying cffi/pkgconfig.py -> build/lib.linux-armv7l-3.5/cffi
copying cffi/setuptools_ext.py -> build/lib.linux-armv7l-3.5/cffi
copying cffi/recompiler.py -> build/lib.linux-armv7l-3.5/cffi
copying cffi/lock.py -> build/lib.linux-armv7l-3.5/cffi
copying cffi/vengine_cpy.py -> build/lib.linux-armv7l-3.5/cffi
copying cffi/vengine_gen.py -> build/lib.linux-armv7l-3.5/cffi
copying cffi/cparser.py -> build/lib.linux-armv7l-3.5/cffi
copying cffi/api.py -> build/lib.linux-armv7l-3.5/cffi
copying cffi/ffiplatform.py -> build/lib.linux-armv7l-3.5/cffi
copying cffi/commontypes.py -> build/lib.linux-armv7l-3.5/cffi
copying cffi/cffi_opcode.py -> build/lib.linux-armv7l-3.5/cffi
copying cffi/verifier.py -> build/lib.linux-armv7l-3.5/cffi
copying cffi/__init__.py -> build/lib.linux-armv7l-3.5/cffi
copying cffi/model.py -> build/lib.linux-armv7l-3.5/cffi
copying cffi/_cffi_include.h -> build/lib.linux-armv7l-3.5/cffi
copying cffi/parse_c_type.h -> build/lib.linux-armv7l-3.5/cffi
copying cffi/_embedding.h -> build/lib.linux-armv7l-3.5/cffi
copying cffi/_cffi_errors.h -> build/lib.linux-armv7l-3.5/cffi
running build_ext
building '_cffi_backend' extension
creating build/temp.linux-armv7l-3.5
creating build/temp.linux-armv7l-3.5/c
arm-linux-gnueabihf-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -g -fdebug-prefix-map=/build/python3.5-6waWnr/python3.5-3.5.3=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -DUSE__THREAD -DHAVE_SYNC_SYNCHRONIZE -I/usr/include/ffi -I/usr/include/libffi -I/usr/include/python3.5m -c c/_cffi_backend.c -o build/temp.linux-armv7l-3.5/c/_cffi_backend.o
c/_cffi_backend.c:15:17: fatal error: ffi.h: Ingen slik fil eller filkatalog
#include <ffi.h>
compilation terminated.
error: command 'arm-linux-gnueabihf-gcc' failed with exit status 1
Failed building wheel for cffi
Running setup.py clean for cffi
Failed to build cffi
Installing collected packages: pip, PyJWT, async-timeout, Unidecode, python-slugify, pytz, voluptuous, certifi, astral, attrs, asn1crypto, pycparser, cffi, six, cryptography, pyyaml, ruamel.yaml, idna, chardet, urllib3, requests, voluptuous-serialize, bcrypt, MarkupSafe, jinja2, typing-extensions, multidict, yarl, idna-ssl, aiohttp, homeassistant
Running setup.py install for cffi ... error
Complete output from command /usr/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-build-zl92_0cc/cffi/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-vxq0fgdp-record/install-record.txt --single-version-externally-managed --compile --user --prefix=:
running install
running build
running build_py
creating build
running build_ext
#include <ffi.h>
Command "/usr/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-build-zl92_0cc/cffi/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-vxq0fgdp-record/install-record.txt --single-version-externally-managed --compile --user --prefix=" failed with error code 1 in /tmp/pip-build-zl92_0cc/cffi/
